Tranny removal with longtubes
Old 05-14-2006, 05:36 PM
UltraZLS1's Avatar
Default Tranny removal with longtubes
Can the transmission be removed in a 6 speed ls1 f-bod with long tube headers still in place?
It looks fine except for the part of the bellhousing where the starter goes...it looks like it will hit the header. The header hangs over this area about 1/4 inch.
Anyone know for sure?
thanks a lot
Old 05-14-2006, 06:29 PM
SiL3NtXWS6's Avatar
Taken mine out 15 or so times with my longtubes still in place.
6 speed with pacesetters.
Old 05-14-2006, 06:33 PM
theinstag8r's Avatar
when i had the stall put in my car they didn't evan have to remove the y-pipe, it slid right through
Old 05-14-2006, 06:40 PM
CHIWS6's Avatar
thats right u don't have to remove the headers to take the trans off
Old 05-14-2006, 06:46 PM
Tech Resident
WhiteKnightZ28's Avatar
What about with an A4?
Old 05-14-2006, 06:55 PM
UltraZLS1's Avatar
has anyone done it with flowtechs or hookers? They are both the same shape I think...but the flowtechs get the premium welds and flanges
whiteknight...yes it can be done with an auto...read the above post about removing for stall
Old 05-14-2006, 07:49 PM
Tech Resident
^^^Ok thanks
Old 05-14-2006, 10:44 PM
01350ss's Avatar
I've done it so many times now without removing a single exhast part including the y-pipe. If you have the height, you can angle the trans down far enough to get it past the y-pipe.
Old 05-14-2006, 10:51 PM
That's what she said...
TheBlurLS1's Avatar
I've done it without even removing my true-duals. I had to unbolt the hangers so I could tilt the tranny down to hit the top bolts though.
Old 05-14-2006, 10:54 PM
'02 SLP#686's Avatar
Take the tranny out first, bellhousing second
Old 05-14-2006, 11:12 PM
TheBlurLS1's Avatar
Yes, this is a must, I thought it was a given so I did not mention it.
Installuniversity.com has a nice writeup. Click LSx vehicals then install docs. There's a link to the clutch swap.
LS1howto.com has a torque spec list if you can't find some of them on there.
Old 05-15-2006, 08:53 AM
UltraZLS1's Avatar
I did not know about separating from the bellhousing first. I have never done this when removing transmissions...but I guess if it makes the job easier I am all for it.
thanks for all the help
