3 inch true duals
3 inch true duals
Holy **** is it loud... It's for some reason louder than my friend's set up. Do they get quieter over time or does the owner just go deaf after a while? I was thinking of getting some cats over the next month or so and was wondering if this would quiet it down? If anyone can suggest some mufflers to help kill the sound that would be appreciated too, thanks.
They may mellow out a tiny bit, but they will always be loud (depending on your mufflers). You should get used to it after a while. As for cats...don't do it unless you have to (because of e-check).
I have some bullet mufflers with some spiral looking **** inside them, can either of you guys recomend a muffler with be sound deadening? I dont mind the sound of the car I just think its a bit much when 1500-2000rpm sounds like WOT.
Originally Posted by fast377
magnaflow is pretty mellow off idle.
Also Borla XR-1 is fairly mellow as well.
Both the Magnaflow and Borla are great choices. I tend to like the manflow a tiny bit more.
Dan
Originally Posted by DanZ28
Ditto that!
Dan
Dan
That's what she said...
Originally Posted by GET_SOM
def. dont get cats, they wont quiet it down much.. they'll just kill your power
The mufflers you have are probably Moroso Spiral Flows or Pro-Flo Twisters. They are reguarded as a decently quiet "bullet style" muffler, even though they aren't really "bullet style".
