belt problem???
Old 12-11-2006, 06:07 PM
bluebody's Avatar
Default belt problem???
I have a 99 C5 vette. Just installed iron 6.0 stroker, heads, cam, etc. The belt has been poppin off and ripping, changed it about 4 times, put new pulleys on and still doin it, does anyone have ideas please pm me thanks
Old 12-11-2006, 07:50 PM
TheLS1Kid's Avatar
get a new belt tensioner. that should help
Old 12-11-2006, 07:54 PM
Gold Z's Avatar
Metco billet tensioner....it's worth it's weight in gold.
Old 12-12-2006, 12:00 AM
That's what she said...
TheBlurLS1's Avatar
Katech should solve your problems easily.
Product:
https://ls1tech.com/forums/generation-iii-external-engine/501358-introducing-katech-s-new-design-billet-belt-tensioner-now-pulley-same-price.html
Install guide:
https://ls1tech.com/forums/generation-iii-external-engine/622426-install-guide-katech-billet-belt-tensioner.html
Old 12-12-2006, 12:14 AM
taintedmeat's Avatar
Make sure your crank pulley is on right.
Old 12-12-2006, 01:59 AM
00formLs1's Avatar
pulley alinement could be off.
Old 12-12-2006, 04:31 PM
bluebody's Avatar
Default pulleys
I put a new oem stock tensioner on it still did it, crank pulley on right, everything looks to be in line. Will a aftermarket tensioner fix it...
Old 12-12-2006, 04:50 PM
TheBlurLS1's Avatar
The Katech unit should cure all your ills. You can even adjust how tight it is.
I've seen this problem 1000 times, and seen it fixed every time the same way. It's also go a special "high sided" pulley, to help even more.
Old 12-12-2006, 06:29 PM
LS1TECH Sponsor
Katech_Jason's Avatar
Thanks for doing my job for me.
