When search fails i ask you! Oil pan gasket change..
Anyone got or know of a good write up for this? I know its gonna be a pain in the ***! all i have is a few jacks and a couple jack stands.. Any help is greatly appreciated!
now is the time when you wish you had an aftermarket k-member
You can suspend motor in the engine bay using a crane and remove k-member.. or you can pull the motor and leave the k-member. I would either do A or B and not have to work around things.
i had my pan off to clean it when i did h/c etc. it wasnt to bad, the engine was unbolted and jacked up about 3 inches(intake manifold off) it was easy to get out after that. took the gasket off cleaned it and the pan. lined up the gasket with the pan - then rivited it back to the pan.. looks as it was never touched.
Originally Posted by SnakeKiller
So if you have a aftermarket k-member is there room to change it? I've changed the gasket before when the engine was out so it's not riveted anymore.
