greddy catch can results?????
I've noticed oil consumption and oil in the intake since in installed MAC's I've got my greddy catch can ready to be installed, and I'm wondering if any of you have had any good results from adding this or any other type of catch can. I have to say, i'm not entirely too optimistic about it. Any info would be appreciated.
-Andy
-Andy
Re: greddy catch can results?????
I was having a problem w/oil comsumption and oil in the intake, probably a good reason as to why I detonated on the dyno....
I was going to do a catch can, but then decided to do breater valves, they can be a mess if you are dealing w/a lot of blow by, they drip oil residue onto the headers and it burns off and comes off underneath the car, bad news....
I'm going to try the breathers on the my new motor and if they still have issues I'm going to switch over to a catch can...
Moderator
At SLP day I saw one dude who was running with one
of those compressed air oil/water separators, and
he had about 1/2" of oil sitting in the bottom.
I installed a Greddy can about two years ago and have been using it ever since. I originally used it to prevent KR when I did the cam and it really did help that. I have about 2" of oil sitting in the bottom it right now (which I need to empty), so there is no doubt its working.
I got mine through this place: http://www.turboimports.com/gredoilcatca.html
It showed up within a week and no problems.
Here's another, cheaper one, but I have no experience with them: http://www.subarustore.com/gredoilcatca.html
Zshark,
If you're talking about the catchcan (as opposed to a breather or something) then it doesn't matter which style of valve cover you have as long as it has a PCV line running out of it. The can just goes somewhere inline between the the valve cover and the TB - its a universal fit. Just make sure you get the version with the 9mm ends. This allows you to use 3/8" fuel line to run to and from the catchcan.
For anyone interested, I have some decent pics of the can, dimensions, and my installation that I can email.
it can look as good or bad as you want.
depending on how much work you want to put into it.
bottom line is it's a bucket to catch oil in.
why waste more than $5 to do it.
but if you have $$$ to waste more power to ya.
I sure would like to see some pics of it.
kevin@contactmanagement.com
I'll most likely have mine installed tomorrow, will probably snap some pics. What should I use to clean my top end? I've read Sea Foam, but where do ya get this stuff. Just need somethin to clean the oil outta the upper end of my engine.
Another source http://www.optauto.com/webstore/prod...s&dept=876
