What is the cheapest way to make my car louder ?
Old 10-15-2007, 05:06 PM
rrgray8's Avatar
Default What is the cheapest way to make my car louder ?
I know if I remove the cats that will make it louder, anything else ?
Any links on how to remove the cats w/o damage ?
Old 10-15-2007, 05:20 PM
Breaking Stuff's Avatar
Loudmouth is a pretty cheap cat back. Its the most obnoxious thing Ive ever heard. I currently have one. Ive had it with and without cats. Its loud either way. Sounds like **** without cats though.
Old 10-15-2007, 05:23 PM
LS1crazy01's Avatar
A Saws all is the cheapest thing! Or you can get a manual cut out that uses the wing nuts and put that before your muffler. I think there like 20 bucks. I wouldnt remove the cats unless you are gonna do headers unless theres a way to keep the rear o2's on it cuz it will run like shiznit with out them.
Old 10-15-2007, 05:38 PM
Sweet71's Avatar
X2 Hack the muffler off...but its just that....hack
Old 10-15-2007, 05:42 PM
NHRAMAN's Avatar
Location: Vancouver,[KITSILANO].B.C. Canada *WestCoast*
Lightbulb
..............cutout...............
Old 10-15-2007, 05:44 PM
rrgray8's Avatar
how much $$$ are electric cut outs ? are they hard to install ? how would it sound ?
Old 10-15-2007, 05:45 PM
95 Z28's Avatar
How cheap is cheap? Don't get into "removing" your cats...you'll most likely snap the bolts and end up with a headache for something that isn't even worth it. Two best choices would be get a cutout or replace your stock muffler with a piece of exhaust tubing. I vote for the muffler delete with a pipe in there.
Old 10-15-2007, 05:51 PM
rrgray8's Avatar
I would like to only spend around $200 or less
Old 10-15-2007, 07:07 PM
LS1crazy01's Avatar
No I didnt mean the Electric one get the one that uses a plate and wing nuts that you take off your self. I think an electric one is 150$ I never installed one though. How loud do you want it? If you want it loud all the time you can buy a single spiral flow muffler or a dyno max and hack off your exhaust and weld it up be for the axle with 1 turn down. That would only cost 50$ for the muffler and like 5$ for the turn down.
Old 10-15-2007, 07:09 PM
JScamaro's Avatar
Cut off your y pipe and muffler if you want loud for cheap.
Open headers
Old 10-15-2007, 07:39 PM
rrgray8's Avatar
quiet until I wanna play ............and when no cops are around
Old 10-15-2007, 07:47 PM
joblo1978's Avatar
Cheapest AND loudest while being able to go back, two cutouts right after the headers, or exhaust manifolds, whichever you have. That will be loud!
Old 10-15-2007, 07:49 PM
rrgray8's Avatar
I am stock.......how loud will one be ?
Old 10-15-2007, 08:13 PM
DSkyles's Avatar
Just put a cutout on the I pipe before the over the axle pipe. If you have cutouts right after the header and you still have knock sensors you run the risk of setting those sensors off, retarding your timing, and slowing the car down. A cutout sounds good with stock manifolds and cats, and also sounds good if you ever got headers/ORY
Old 10-15-2007, 08:53 PM
crapyboy750's Avatar
Well i guess with having a stock exhaust then your muffler is most likely welded on. But i have a borla bolt on exhaust and i just took the muffler off and it is alot louder. And i havent had any problem with cops yet.
Old 10-15-2007, 09:24 PM
DaveX's Avatar
Just remove the exhaust at the manifolds. Your 02's won't be happy but it is the cheapest way to make it loud.
Old 10-15-2007, 09:58 PM
INMY01TA's Avatar
Best advice yet.
Old 10-15-2007, 10:50 PM
NemeSS's Avatar
cut out after the y pipe merge, cut tips off the muffler
or just cut out.
Old 10-15-2007, 11:05 PM
3.4camaro's Avatar
Drill holes in the manifolds.
Old 10-15-2007, 11:47 PM
LS1crazy01's Avatar
Your joking right??
Quick Reply: What is the cheapest way to make my car louder ?
