Help....Overheating after Heads and Cam.
I tried search, but no answer.
Finished H/C
Car is over heating and the gauge goes slowly to the Redline. Fans kick in and the 2 lines by the Rad cap are not mixed up.
When the car is running its asking for more and more Dexcool. It sucked up one and a half jugs. The Resauvour is full, but not letting the dexcool to flow to the rad. I checked the oil and its only oil.
Any ideas? the car is not leaking anywhere.
Finished H/C
Problem fix. I guess it was air in the system
no iam filling it from the radiator. I did add some into the reservore.
Now there is a small leak coming from the front cross over pipe. Its actually on both sides. Is that common?
sounds like you have a air pocket on your system. let your car idle til you see it start to overheat. let it cool and then top off the radiator again. keep doing until it does not overheat anymore.
ohh don't remind me on Remembering things. This is my Friends 98 TA and we were technically done last week, but there was no OIL pressure. Do you know why? Because one of us FORGOT to put a O-Ring on the Pick-up Tube. DOH!!!
Can I use RTV? if no where can I get the new o rings? Part #?
I wouldnt, it could end up where you don't want it, and stop things up. As far as the o rings, no, I don't know the pn. If you have them, but their just in bad shape, you could use them to match up a new pair. Otherwise, prolly gonna have to go to the dealer. The only problem with that, is most likely you'll have to purchase the entire crossover assembly. Good luck.
