ls1 drive shaft
Old 12-31-2007, 05:19 PM
killerv6's Avatar
Default ls1 drive shaft
i was wondering if the ls1 camaros drive shafts are alum when they came out stock my friend said they did if so what year did that start thanks.
Old 12-31-2007, 07:02 PM
silverLSWON's Avatar
i think all ss/s and ws6's have them, some reg z28's and ta's have them. my g/f 2000 t/a came with a steel one
Old 12-31-2007, 07:34 PM
2001NBMZ28's Avatar
The M6 cars and A4 3.23 cars were supposed to come with the alum driveshaft, mine is steel and originally 2.73.
Old 12-31-2007, 10:20 PM
luis_ws6's Avatar
Yea I just realized that this past weekend when I was doing my headers.
Old 12-31-2007, 10:33 PM
Evans752's Avatar
Yes all LS1 had aluminum driveshafts 1998-2002 The LT1 1LE car came with aluminum driveshafts and if your car LT1 (1993-1997)was under warranty and you had a vibration at speed they would put one in it if the mechanic was worth a crap and kept up with bullitins. LOL
Old 12-31-2007, 11:16 PM
Z28/2002's Avatar
Location: Your girl's back door giving her the long stroke while you're at work
M6 and A4 3.23 cars had the aluminum DS
A4 2.73 cars had steel
Old 01-01-2008, 01:19 AM
JScamaro's Avatar
When should one consider replacing the stock aluminum drive shaft?
Old 01-01-2008, 06:07 AM
Z28/2002's Avatar
With your car being an auto you won't have to worry about it much unless you get crazy with the car. I was cutting 1.5xs 60 fts with 3.42s and a aluminum DS and never had a problem. But search around in the Gears & Axles forum, there is some info in there about your question
Old 01-01-2008, 08:56 AM
DaveX's Avatar
Not so, many (like mine) came with a steel driveshaft.
The factory aluminum one has been known to break. If mine had one I would upgrade it to a better aluminum one or a factory steel one.
