ls6 intake and tb vs fast 90 mm
Old 01-11-2008, 06:36 PM
silvers's Avatar
Default ls6 intake and tb vs fast 90 mm
I have a s-10 ls6 and i would like to put some bolt on upgrades.
Do you think the fast intake is a good vs $$/hp.
Thanks
Old 01-11-2008, 07:12 PM
Shawn @ VA Speed's Avatar
what other mods do you have,it may be benificial if you have bigger cam and heads
Old 01-11-2008, 07:47 PM
Red99TA's Avatar
A 90/90 setup is expensive and you don't gain much unless you either have a big cam or a heads/cam combo as mentioned.
Old 01-11-2008, 09:19 PM
silvers's Avatar
thanks i just came to buy a s10 ls6 so i am still new in v8 mods!
Old 01-12-2008, 01:53 PM
Pewter02WS6's Avatar
Don't need it unless your going with a 408 stroker or big block. Don't even really need it with big heads and cam. Go with the ls6 intake and TB. With the fast 90 setup you'll lose power through the bottom end and midrange.
Old 01-12-2008, 02:47 PM
Johnnystock's Avatar
you will benefit from 90 even if you only have bolt ons. BUT, it offers solid gains with H/C
you should try a search...
https://ls1tech.com/forums/appearance-detailing/761478-porting-prepping-painting-fast-90-intake-write-up-tons-pics.html
35rwhp over ls6: definitly worth it.
Old 01-12-2008, 02:53 PM
and its a LS1, not a 408. The FAST 90 was designed for the LS1 at first.
Old 01-12-2008, 05:15 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
Show me this LSx Big Block you speak of.
It can be that much. Serious mods will get you that kind of gain. I picked up 12 over LS6 but I run big cam and ported heads. It was worth a switch to me, but most ppl would frown on it.
Old 01-12-2008, 05:56 PM
Red99TA's Avatar
It was worth it to me when with just a cam and bolt-ons. I added the 90/90 with an underdrive pulley and picked up 29RWHP/22RWTQ.
Old 01-12-2008, 06:01 PM
99mongooSS's Avatar
no ****...theres no lsx big block
Old 01-12-2008, 06:16 PM
This 35rwhp gain was from a Mamo ported unit.
Quick Reply: ls6 intake and tb vs fast 90 mm
