fast intake ?
Old 03-02-2008, 01:17 AM
minizcustoms's Avatar
Default fast intake ?
ok guys i know this is a dumb question for you but i just want to be 100% positive before i buy this stuff. when you buy the fast 90 intake you cant use your stock tb right. you will have to get a 90mm intake correct. please let me know if im right or wrong. thanks...
www.minizcustoms.com
Old 03-02-2008, 01:34 AM
Restricted User
WS6nJAX's Avatar
you are correct sir. you will need a 90mm tb.
Old 03-02-2008, 01:35 AM
00bluews6's Avatar
if you get the 90mm intake you will need a 90mm tb it wouldnt make sence to put a 75mm tb on a 90mm intake you will like thw set up when all said and done
Old 03-02-2008, 01:55 AM
ok thanks guys i just wanted to make sure. what kind of difference do you think i will notice with doing this mod? the only other thing that is done is slp lid with flowmaster exhaust
Old 03-02-2008, 06:55 AM
Viper's Avatar
I think you will notice more power and a quicker throttle.
Old 03-02-2008, 07:03 AM
Johnnystock's Avatar
If you have a stock engine and no bolts on, you wont see any gains. BUT, with H/C/I, its worth it. Get a LS6 if you have minor bolts on.
Old 03-02-2008, 08:25 AM
TLewis4095's Avatar
He is right, the FAST really shines with the rest of the restrictions opened up. The motor is a big air pump & is only as good as the flow lets it be.
Heres the TB I suggest: But in the 90mm size.
Old 03-02-2008, 07:56 PM
yeah i plan on getting a cam and head combo but not until winter. its the kit in summits magazine for the trick flow package. i will look into that rev throttle body. but when i clicked on your link www.revxtreme.com i saw the catch can kit. what exaclty is that and what would it benifit to have.. thanks again guys
Old 03-02-2008, 09:49 PM
TLewis4095's Avatar
Preventing oil vapors from entering the intake manifold is a common problem with built LS motors. The oil mist causes detonation & loss of power and the catch can is a very effective mod thats easy to install. The RevXtreme catch can utilizes a perforated downtube to help disperse the crank case vapors over the entire inner surface for maximum condensation & seperation. Simply plumb inline between your vacum outlet on the intake manifold & the breather system.
And only $69!! Call JP today to order: 813-628-0080
