make sure your MAF is clean if you run K&N filters
Old 08-25-2003, 07:38 AM
Fireball's Avatar
Default make sure your MAF is clean if you run K&N filters
On a dyno session I had on Friday my car was running quite lean (where it wasn't a problem in the past). It was close to 14.0:1 A/F at WOT
We tuned it back to 13.0 but then realized the MAF was covered with K&N airfilter oil We pulled the MAF and cleaned it and made another dyno pull. A/F then dropeed from 13.0:1 to 12.0:1 So after all that fuss, the original fuel maps were reinstalled and the A/F is now a clean 13.0:1 across the board.
CHECK YOUR MAF SENSORS
This has been a public service announcement
Old 08-25-2003, 07:57 AM
KRAZY K 2000 TA's Avatar
Default Re: make sure your MAF is clean if you run K&N filters
Same herewent to world nationals at norwalk Ohio bought new K&N about four runs then ses light cam on didnt pay any attention just got slower fixed it at rest stop on way home,By the way drove it there and back 3 hours each way
Old 08-25-2003, 08:36 AM
Retsik's Avatar
Just out of curiousity, what would be the safest way to clean the MAF wires?
Old 08-25-2003, 09:21 AM
Viper's Avatar
I use a q-tip, and electrical contact cleaner. Had the same problem in May at an autox event in rain; sucked water past the filter onto the MAF, car ran like crap.
Old 08-25-2003, 09:46 AM
BAD XXX's Avatar
So if I'm running rich, I can put some K&N oil on my MAF to lean it out?
Old 08-26-2003, 10:29 AM
pimpmaro's Avatar
lmao!
Old 08-26-2003, 03:16 PM
CHRISPY's Avatar
Use contact cleaner in a spray can works great.
Chris
Old 08-26-2003, 03:37 PM
7 Second Club
NicD's Avatar
Where do you pick up contact cleaner in a spray can?
Old 08-26-2003, 06:32 PM
soundengineer's Avatar
any electronics store....Like Radio Shack...
Old 08-27-2003, 12:10 AM
BAD XXX's Avatar
Wait a second, doesn't the elements of a MAF go into a "burn-off" cycle once the engine is shut off to burn away any contaninants?
Old 08-29-2003, 12:26 AM
Richard@WCCH's Avatar
As I understand it, the earlier LT1 had MAFs that had a burn-off cycle. The LS1 cars do not have this feature.
BTW, Hi Castaic neighbor!
Richard
