just installed ms3 cam and.......
well i just got done installing my ms3 longtubes lingenfelter intake bbk tb, and lid and now the car wont down shift when i mash it...... shifts normally ok maybe alil firm or so, im wondering is this due to the idle set screw being messed with? if so what can i do to fix it?
well i have a p0121 code which is tps out of range, so ive done some re adjusting and cleared the codes, im going to drive it a bit to see what happens. Im wondering if i may have a vacuum leak possibly also....
You're not pulling enough vacuum at idle. The stock settings has the tps going nuts at anything above 65 kpa. Get the car tuned (STOP GOING WOT OR PUTTING THE CAR UNDER LOAD UNTIL THEN!) and have the tuner move the error reading to something like 85kpa. It will short shift at wot and will sometimes not downshift because of that code.
Thanks for the info guys, here's the thing I installed the tb before the cam swap and the idle was a bit low so I hit the bump stop up a bit. Now when the cam went in I jumped it up alot more to keep the car running and that's why I think the code went off. Im going to have to check the voltage and re set it to what is supposed to be at idle. I did a bit more adjusting w/o a volt meter and now it down shifts just not the way it normally would. BTW, anyone know what the voltage should be at idle? .5v? I do think there is a vacuum leak also I'll try spraying carb cleaner or something around the manifold......
Found the spec is .6v so i set it to that and it seems to be better. Other issues are the car likes to rev up and basically drive it self, ill let off the gas and it will keep accelerating sometimes and others it will be ok. Im thinking that is a vacuum leak..... i'd hate to get it tuned and find out that a vacuum leak was causing alot of the problems. If i hook a vacuum gauge i should be able to know right? What should vacuum be w/ that cam?
[QUOTE=i'd hate to get it tuned and find out that a vacuum leak was causing alot of the problems. [/QUOTE]
What part of YOU HAVE TO GET A TUNE do you not understand? A tune is a must they can tune a lot of that out, when you bumped up the set screw you moved the throttle blade and the PCM is showing throttle input from the TPS when you let off the throttle, do it right and stop adjusting thing that you dont know what they do.
A tune is definetly in order with a cam like that. Your gonna gain more power too if you get it tuned and your tuner will be able to get rid of your codes and it will run 110% better.
To original poster, your **** will be blown up in no time, do some research.
Here's another thing that i think is absolutely hilarious, everyone on here going on about your going to blow your **** up w/o a tune.... You would have to be making serious horsepower and have a lot of detonation in order to pop a NA motor. And FYI I have a wide band on the car.
For anyone who wants to actually help me out, I've decided will cap off the pcv to eliminate that as a possible vacuum leak, if that doesn't fix it I'm going to pull out the direct port kit and put pipe plugs in the manifold ports and try again w/ starting fluid. Right now I have too many things that could be leaking.
I never asked why there was a tps code, and the trans is under control. I've run plenty of large cams on other cars untuned for long enough periods w/ no trouble. Yes, fuel can get into the oil from running overly rich and I'm aware of it and it's something to keep an eye on.
But as stated, all I'm trying to do now is find a vacuum leak, once I can pin point that and eliminate it, then I'll look into tuning. (BTW I don't claim to know everything, it's just annoying when your looking for help and people w/ no clue immediately say you need a tune or your car will blow up.....)
I had a problem with my FAST TB doing something similar to what you are describing . It turned out to be the o-ring on the IAC was broken and was letting unmetered air in .... also known as a vacuum leak LOL ! It drove me nuts trying to find out what the problem was . I replaced the o-ring and things are back to normal again . Might be worth a shot to check yours out . Hope this helps .
I had a problem with my FAST TB doing something similar to what you are describing . It turned out to be the o-ring on the IAC was broken and was letting unmetered air in .... also known as a vacume leak LOL ! It drove me nuts trying to find out what the problem was . I replaced the o-ring and things are back to normal again . Might be worth a shot to check yours out . Hope this helps .
It's funny to me that you'd even floor the car to know it's not downshifting at WOT.. obviously your foot is heavier than your brain. How about all the cam bearing shavings you're going to find in your oil after maybe 50 miles.. you're not worried about uhh spinning a bearing? And you're out there flooring it and telling us we don't have a clue.. nice, good luck.
lol, ok dude....... And turns out the intake gasket is leaking so I'll be popping that off shortly and everything should be ok. Thanks to the people who actually gave me some useful insight.
