ported 5.3 MS4 PTV
Old 05-05-2009, 09:53 PM
azceta's Avatar
Default ported 5.3 MS4 PTV
I did a search and cant find anything. I'm looking at adding ported 5.3 heads and an MS4 to a stock cube forged lower end.
1. Are there any PTV issues will fly cutting take care of?
2. What pushrods will be needed? (cant have it down for long. F-ing HOA)
Old 05-05-2009, 10:39 PM
KingSS's Avatar
If you are going forged the pistons should have a valve relief which will give you enough room to run the heads with that cam. PR length would probably have to be measured, i would want to mill those heads and throw some more compression in a motor like that.
Old 05-05-2009, 10:41 PM
tripblackls1's Avatar
you will need to flycutt the pistons im not real sure how much but last time i talked to tsp they said about .080
Old 05-05-2009, 10:58 PM
cellulis44's Avatar
It's been established, if he has aftermarket pistons, his PTV should be fine... always good to measure.
as the above said, check the rocker swipe with a adjustable pushrod.,, only way to be sure you valvetrain geometry is good. otherwise, you'll end up with a noisy unstable valvetrain, and worn out valve guides.
Old 05-06-2009, 09:58 AM
azceta's Avatar
Sorry its stock cube ls1 how far should I mill them down to be?
Old 05-06-2009, 10:08 AM
Jon@Texas-Speed's Avatar
If you are flycutting, I would mill them down to 59-60cc to set the compression up around 11:1. At the point that you are flycutting, there is no reason really not to. These motors respond really well to compression so why not go ahead and get as much as you can but keep it friendly enough for the pump.
Jon
Old 05-06-2009, 10:15 AM
LS1Tech Premium Sponsor
Sales2@Texas-speed's Avatar
Are you putting larger than stock valves in the heads (wasn't stated in OP)?
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old 05-06-2009, 10:23 AM
azceta's Avatar
Was gonn try to keep stock size valves in it. Would there be any PTV problems in no flycutting or milling was done? Aren't they the same config as 243 just smaller combustion chambers?
Old 05-06-2009, 10:26 AM
With stock valve size in the heads and if they are unmilled, you shouldn't have a PTV issue with the MS4 cam.
Jon
Old 05-06-2009, 10:34 AM
azceta's Avatar
Any ideas on what size pushrod need to run would like to go ahead and order something can't keep it torn down for long.
Old 05-06-2009, 11:13 AM
It's always a good idea to measure but a 7.400 or 7.425 should do the trick.
Old 05-06-2009, 11:35 AM
azceta's Avatar
Thanks for all the help
