Trex Cam question
Old 06-26-2009, 11:29 PM
LSXFORMULA99's Avatar
Default Trex Cam question
I am looking into buying a trex cam. and everyone says they have valve clearance issues, afte taking the heads off my buddies car we found his valves were kissing the pistons a lil. he has the basic trex with 110lsa..
My question is, if you had a custom grind trex with 111lsa or 112 would that help with valve clearance??
I
Old 06-27-2009, 12:07 AM
98blackbirdta's Avatar
I'm not sure about the cam but I know you could get ur pistons fly cuted
Old 06-27-2009, 11:00 AM
SS4Luck's Avatar
i dont believe the LSA would make a difference its more the Duration/Lift setup on that cam, which is through the room as far as duration for a 346. That cam puts down some serious times/numbers though. Looking back on it i should have gone TREX v.3 not my MS4
Old 06-29-2009, 03:53 PM
thats what i thoght. but doesnt the ms4 have more lift and dur. than trex?? and the trex has the worst PVC
Old 06-29-2009, 04:10 PM
ThunderStruk's Avatar
Trex has more duration but less lift.
Old 06-29-2009, 05:23 PM
NemeSS's Avatar
i would go ahead and cut in vr's anyway,
while your there go ahead and mill the heads also for more scr
Old 07-04-2009, 12:54 PM
oh ok. im just ganna buy a ms3. lol
Old 07-04-2009, 02:09 PM
somws6bird's Avatar
Buy the TREX, you won't be disappointed, trust me !
Old 07-04-2009, 05:01 PM
Spectre86's Avatar
saw your sig.
T-REX, Patriot Stage 3 LS6 Heads
did you have to flycut? Did you have the heads milled? What CC are they?
Old 07-04-2009, 05:06 PM
transamfreak01's Avatar
thats going to depend on the person. with my baby cam i ran 12.1 the first run on the set up. i cannot handle a cam that big. do you dd your car?
Old 07-05-2009, 05:35 PM
somws6bird's Avatar
Don't get me wrong, baby and mid sized cams get the job done well
But from the moment I heard a Trex car and saw what kind of power they were making I knew I had to have this cam.
As for the heads, I believe they are 68cc, they are not milled and I did not flycut the pistons
I don't drive it daily, if your wanting a cam for a daily driver, this is prob not the type of cam your looking for, any big cam can be tuned to drive excellent though. I would suggest something in the 228-230's range for a daily.
Old 07-05-2009, 08:30 PM
i really would buy the trex if i wouldnt have to be worried about the PVC..i love the power they make and they sound bad *** lol. idk i will thnk about it
Old 07-06-2009, 10:42 AM
LS1Tech Premium Sponsor
Jason 98 TA's Avatar
I completely disagree with this statement. I have dyno tested these two camshafts side by side on the engine dyno. If you'd like your welcome to come down & compare the two side by side on my engine dyno.
Jason
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Old 07-06-2009, 04:19 PM
evangto87's Avatar
not to thread hijack.... but will my -4cc valve reliefs be enough for a milled 36 thousandths 243 head and a .040 head gasket with my MS4 cam? obviously ill be doing a clearance check when i assemble. But im bring my heads to the machine shop tonight and wondering if i can go that low. thanks
Old 07-06-2009, 04:29 PM
AznMuscle's Avatar
With my stock 243 heads, my 242/248 (cam is same duration as the Trex with more lift) 111 lsa doesn't have issues. Just my quick .02.
Old 07-06-2009, 04:35 PM
TooLateVTEC's Avatar
LSA DOES reflect PtV clearance as its a relation of valve overlap.
Old 07-07-2009, 11:07 PM
thats what i said. so if i was to get a trex cam with 112lsa would that make it a lil safer
Old 07-07-2009, 11:08 PM
Jason
could you post the dyno graphs.
Old 07-08-2009, 09:21 AM
Without any proof to back up my claim, I would say it would help.
How much it will help I have no idea.
Do they make that cam on a 112, or is it a special order type of deal.
Reason I ask is if they engineered that monster on a 110, and you change it to a 112 that throws the whole powerband off.
If it was me man, I would flycut the pistons and do it right. Someone makes a tool to cut the pistons in the motor using the valve guide. I just saw some pics last week I think of someone using it in a vette I think.
Good luck with whatever you do.
Old 07-08-2009, 03:03 PM
Spectre86's Avatar
any videos of your car?
Quick Reply: Trex Cam question
