Installing rocker arms???
Old 07-11-2009, 05:46 PM
Boo"SS"t's Avatar
Default Installing rocker arms???
Do I have to follow the sequence procedure for installing rocker arms (well, according to my HAYES manual) like they do on LT1 engines? ...you know, putting the #1 piston top-dead -center and so on..... I don't get why you have to on LS1's since they're non-adjustable, I know you have to on LT1's since they're adjustable and must be set within allowable backlash. -Thanks!
Old 07-11-2009, 06:06 PM
98RedBird's Avatar
No, I don't believe so. Just install them, torque them to I believe 22ft-lbs (Check that before you do it, I'm not sure on that torque value) Rotate the motor over and re-torque. You may want to put some thread sealant on the bolts just for good measure.
Old 07-11-2009, 06:08 PM
bearcatt's Avatar
Yes there is a sequence for tightening the rocker arms.
TDC = Cylinders 1 & 6
Than
1/4 turn or 90 degrees on crank puller = Cylinders 8 & 5
Another 1/4 turn or 90 degrees on crank puller = Cylinders 7 & 4
Another 1/4 turn or 90 degrees on crank puller = Cylinders 3 & 2
Some guys just torque them down and will be ok too.
I follow the sequence, then check them all again without sequence.
Old 07-11-2009, 06:21 PM
S10xGN's Avatar
Correct! Follow the sequence or risk stripping the bolt holes in the head.
Russ
Old 07-11-2009, 06:31 PM
Boo"SS"t's Avatar
Russ
Hmmm....I don't see how you would, that's only 22ft-lbs. maybe I'm just missing something.
Old 07-11-2009, 06:40 PM
S10xGN's Avatar
Yup, you're missing the fact that you'll be compressing the valve springs with that bolt *if* the cam is not on the base circle. Go ahead and try it, let us know how it goes...
Russ
Old 07-11-2009, 06:42 PM
bearcatt's Avatar
Sequencing doesn't take much longer and it makes it easier to install the rocker arms with
the cam on base circle.
This way you only have your preload on the lifter and very little valve spring
compression. Without sequencing you will have some cam lobes at higher liftpoints, thus requiring you to compress the valve springs down hard with the rocker arm bolts and aluminum head threads.
Old 07-11-2009, 08:07 PM
mknight759's Avatar
you have to make sure there is no pressure on the springs to get the right amount of torque thats why there is a sequence
Old 07-11-2009, 09:27 PM
98RedBird's Avatar
Yeah, makes sense. I've never had any trouble with the ones that I've done the way that I described in the second post, but from now on I'll probably be sequencing them as described here. Just makes more sense and I can't see it taking but a few extra minutes. Good info guys!
Old 07-11-2009, 10:12 PM
Boo"SS"t's Avatar
Well, I guess it does makes sense. Thanks guys!
Old 07-12-2009, 08:38 AM
f-bodyguy's Avatar
i wish i would have read this i just start in the middle(becausr its aluminum)and work my way out...thanks guys
Old 07-12-2009, 06:59 PM
vettenuts's Avatar
Here is the correct GM procedure.
Old 07-12-2009, 07:05 PM
bearcatt's Avatar
There you have it ^ .
