Patriot stage 2 ls6 59cc heads a good choice?
Old 09-13-2009, 02:07 AM
ls1chris's Avatar
Default Patriot stage 2 ls6 59cc heads a good choice?
Heads Ls6 Stage 2 Patriots 59cc,Do you guys think they will be a nice addition to my setup.I have a chance to pick up a set for around 750 with Gold Double valve springs.I was original looking at some 5.3 heads.But for the price of these if they will be beneficially to me i may pick them up. So would they be good for my setup and how much power should this pick me up. im currently at about 370-375rwhp
lt headers
xpipe
ls6intake
torquer v2 cam
free mods
lid
few other bolt ons.
Old 09-13-2009, 07:08 AM
NAVY's Avatar
i think GM 5.3 62cc
Old 09-13-2009, 09:45 AM
ls1chris's Avatar
...bump
Old 09-13-2009, 09:57 AM
LSX Mechanic
Damian's Avatar
From my experience, Patriots are good for 25-30rwhp with the Stage 2's.
Old 09-13-2009, 10:05 AM
Slow 346's Avatar
For the price, id try them. You can always resell them down the road if your not happy.
Old 09-13-2009, 10:24 AM
allthrotle's Avatar
Im running them on my car, I made some decent power with them. check sig the 2001 ws6.
NateZQ8's Avatar
I like mine, although I have the 64 cc's
Old 09-13-2009, 10:36 AM
GR8GAME's Avatar
I have stg 2 59cc paired with a 224 cam lt headers and fast intake and i'm making 425hp 390tq
Old 09-13-2009, 11:26 AM
PREDATOR-Z's Avatar
With a TV2 you'll need to flycut your pistons.
Old 09-13-2009, 07:54 PM
LSX Mechanic
Damian's Avatar
I installed a set of Patriots/61cc on top of Ed's 232/236 .600/.600 tiger shark cam and still had room. It was around ~.090 intake IIRC.
Old 09-13-2009, 10:33 PM
TXZ28LS1's Avatar
alot of people bash patriots, but if you check out the dyno section, the last few members using patriots have made good power for them.
Old 09-14-2009, 08:51 AM
LS1Tech Premium Sponsor
Jason 98 TA's Avatar
We can put together a cylinder head setup with proper milling to get you the best possible compression while keeping good piston to valve clearance. I'm not sure how Patriot sets they're stage 2 heads up, but valve depth & the valve itself plays a important part in what kind of clearance your going to have.
If you get some free time give us a call & we can discuss options with you. The PRC Stage 2.5 LS6 heads would probably be what I'd consider running if I was on a budget. They might cost just a little bit more, but in the long run I think you'd be extremely happy with them. They're right about $1200 if you use your existing spring kit. If budget wasn't as much of a concern you could buy the PRC 215s for under $2000 if you use your existing springs! That would be a awesome option because you'll get all the advantages of a aftermarket casting with smaller runners, thicker deck, smaller chambers, and good p/v clearance!!
http://www.texas-speed.com/shop/item...d=993&catid=20
http://www.texas-speed.com/shop/item...d=134&catid=40
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Old 09-14-2009, 10:46 AM
PREDATOR-Z's Avatar
It depends on what one considers tight, and as we both know, each individual setup should be measured to be sure. too many variables....
TV2 on 112+4 would be too tight for my bones (street speaking).
Quick Reply: Patriot stage 2 ls6 59cc heads a good choice?
