Can you just replace the #7 sleeve?
The following users liked this post:
ls7racer (02-14-2021)
LS1TECH Sponsor
Bore damage
I assume you have an LS1 or LS6 block being in the Gen III section. Take a good look at the bore to make sure the sleeve isn't cracked. You may be able to get the aluminum off with HCL as someone suggested. Check the other pistons for cracked ring lands, etc. You then have a choice depending on what you find, of getting another block and one piston or honing your block for a set of .005" over pistons. It is possible to put a .005" over piston only in 7 if the block and the rest of the pistons are good and you are on a tight budget.
I don't like sleeving the LS1 or LS6 blocks with dry liners to repair them. I have done a few successfully but there is no guarantee. There is a coolant passage between the bores on these blocks. That's why we, Darton and I, developed the MID wet liners for these Gen III blocks. The later blocks, Gen IV are true siamese blocks which I have sleeved hundreds of with both dry and wet liners.
Steve
Steve
__________________
Steve Demirjian
Race Engine Development
Oceanside, Ca.
760-630-0450
web: www.raceenginedevelopment.com/
e-mail: race-engine-development@***.net
Steve Demirjian
Oceanside, Ca.
760-630-0450
Steve
Steve
LS1TECH Sponsor
tuning
Cylinder 7 runs leaner and and possibly hotter than than the other cylinders on these engines with the factory manifold. Don't screw with the intake port. Tune the engine so cylinder 7 is rich enough to keep it out of detonation. In other words, check the plugs during tuning.
When you tune with an O2 sensor, the sensor is reading the average of all four cylinders on that bank. It will not tell you where each individual cylinder is in terms of A/F ratio. Same issue would hold if you had one injector that flowed less than the other three. I repaired a block last month with a cracked #1 cylinder due to a bad injector.
Steve
Steve
__________________
Steve Demirjian
Oceanside, Ca.
760-630-0450
Steve Demirjian
Oceanside, Ca.
760-630-0450
One issue I was concerned with as far as adding more fuel goes is the front hole actually has carbon build up on the piston, from running rich I assume. Assuming that that injector is not running a little leaner than the others. It would be nice if you could do a little tweaking per cylinder.
