ms4 cam ?
Old 12-10-2009, 12:11 PM
SScamaro4's Avatar
Thumbs up ms4 cam ?
do you have to fly cut pistons to install and ms4 ill be running ls6 heads
Old 12-10-2009, 12:15 PM
mastercoryd's Avatar
if their stock, it should fit with 111lsa or 112 but their supposed to have really close clearances
King Nothing's Avatar
search button is your friend
MS4 and flycutting
Old 12-10-2009, 12:16 PM
SScamaro4's Avatar
Thumbs up
ghee thats always nice to know haha
Old 12-10-2009, 12:19 PM
i do what i can to help everyone out!!
Old 12-10-2009, 02:46 PM
LS1Tech Premium Sponsor
Sales2@Texas-speed's Avatar
Correct, with stock valve drop the clearance is tight. With aftermarket valves or milled heads, you need to flycut!
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old 12-10-2009, 06:52 PM
SpeedSlut's Avatar
You don’t HAVE to do anything however I Believe you can run the ms4 with ls6 heads but the ptv clearances will be tight and it is recommended you do it anyways.
For what its worth I would fly cut and not have to worry about it.
Piece of mind and you wont get a bent valve or worse.
Old 12-10-2009, 07:38 PM
SScamaro4's Avatar
nothing in cars has to be easy haha jesus christ you gotta flycut pistons for a cam like wtf but hell like you said better then having a bent valve
Old 12-10-2009, 07:43 PM
blackLS1m6's Avatar
I have the MS4 on a 112 LSA, stock heads, stock bottom end, 7k countless times too no problems.
Old 12-11-2009, 08:19 AM
Ws6kid.'s Avatar
Post
i have long tubes and a ORY and a ls6 intake.
could i get a nice gain out of the MS4 cam?
i want a cam but i dont want to worry much about
valvetrain life and such...
and if i get a cam which one? and what else would i need?
Old 12-11-2009, 09:13 AM
SScamaro4's Avatar
when you do flycut them how much do you go?
Old 12-11-2009, 10:28 AM
SOMbitch's Avatar
I know a guy who went .125 and sprayed a 150 on it no issues. This thread has some pretty good info....
https://ls1tech.com/forums/generatio...ee-almost.html
