500+HP 383 setup
500+HP 383 setup
Me and my buddy are argueing if i can break 500 hp with my setup in my sig with a head swap to PRC stage 3 LS6 or Patriot Stage 3 LS6 heads and a Walbro pump, FAST fuel rail setup. At 1300ft elevation. I think it can be done. I appreciate any comments.
1 Post
+1 a little info is needed on the cam. If that cam is in the 236 range and .600 ish lift you should be able to hit even being at 1300 ft elevation.
My cam is a 239/243 .623/.623 113+3 and you can see the numbers in my sig. Granted you have a few less cubes, I'd think if your cam is comprable you'd make 500ish to the wheel. Whats the compression ?
LS1Tech Premium Sponsor
Comparing those two cylinder heads just because they're priced similar is not a good comparison. You'll definetly find the PRC heads are way underpriced for the quality & flow they provide. Checkout the PRC 227 heads also, they're not a lot more expensive, but they've proven to make over 500rwhp with ls2 applications. With a 383 it should be no problem at all!
http://www.texas-speed.com/shop/item...=1068&catid=40
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Jason
2005 Twin Turbo C6
I was thinking the fuel rail was gonna give me a restriction on fuel? I forgot to put my cam in my sig=232 235 640 598 112LSA. Thank you for all the comments, I was thinking about puting like a 50 shot of spray to start out on, I havent ever messed with nos.
532/472 with my 383
tfs 215 milled 61 cc's 11.6 c/r
y/t ultralights rockers
vrx5 cam
ported fast 92- by vengeance
ported ls2 t/body by vengeance
meziere
ati underdrive
callaway honker intake
kooks 1 3/4 headers
kooks 3x3 catted xpipe
corsca exhaust
exedy twin disc clutch
fast 36 injectors
thats about it....
i have sat side by side with an 09 zr1 from 20-150
vrx5 cam
meziere
ati underdrive
kooks 1 3/4 headers
corsca exhaust
fast 36 injectors
thats about it....
532/472 with my 383
vrx5 cam
meziere
ati underdrive
kooks 1 3/4 headers
corsca exhaust
fast 36 injectors
thats about it....
vrx5 cam
meziere
ati underdrive
kooks 1 3/4 headers
corsca exhaust
fast 36 injectors
thats about it....
I only put down 425 rwph 416 ft lb. Idk if that is what it could really put down, the dyno tune i got i think is shitty. The heads are stock heads with a stage one port job, milled with comp rocker arms, 7.400 pushrods, manley max .650 lift springs, LS7 lifters, stock valves, stock gasket, with the block being decked. Im looking for budget heads like patriot and prc, i was gonna reuse my springs, lifters, pushrods, and rockers, so i just need the valves and retainers. Trickflows is a little pricey...
