Looking for 400whp cam only...suggestions?
As it sits, my car has the following mods:
2000 LS1/M6
Hooker longtubes
80mm TB
Lid
Moser 12 bolt
I was told the following combo would get me there....
Vengeance VX5 cam
TEA Dual Gold springs
LS6 intake manifold
and of course a dyno tune
Now I know nothings guaranteed, and not all cars are equal...but I'm looking to get around 400whp...thoughts? suggestions?
2000 LS1/M6
Hooker longtubes
80mm TB
Lid
Moser 12 bolt
Vengeance VX5 cam
LS6 intake manifold
with just the cam, intake and tune i highly doubt you will need injectors or fuel pump. It never hurts to get bigger injectors but you can always go use the chart to determine the duty cycle of the inectors.
This combo will get you the 400whp mark but it depends on what type of dyno you are using. An m6 will always dyno higher and im assuming you will be tuned on a dynojet. If you were to get tuned on a mustang dyno I would have to say no you will not see 400whp.
You will be much happier if you build a setup for your goals other than just trying to achieve a rwhp number with one major mod. But yeah a big cam will get you to 400 rwhp but your under the curve power and torque may not be where you want it. Adding a few extra mods will get you more power both peak and acrossed the range.
