Help me get 9.5 compression
I was looking into buying a used 370 shortblock with -2cc pistons. I know im gonna need 72cc heads, but what gaskets do I use to achieve 9.5 to 1 compression? I tried using an engine compression calc. but it looks like ill need a thick head gasket...
Flatout gaskets
Check out these guys. You can get any thickness in the rubber coated copper and any bore. We have used these on twin turbo street cars no problems.
www.flatoutgaskets.com
877-837-9200
They have mls in 0.051", also the rubber coated copper are any bore so you can get them the recomended 0.020" larger than bore size and they are off the shelf in a 0.072" thickness.
Aleck
877-837-9200
Aleck
