LSX guy who's s10 wont start..status post head gasket replacement
Old 06-13-2010, 04:34 AM
firstinlastout86's Avatar
Question LSX guy who's s10 wont start..status post head gasket replacement
Not sure where I should have posted this on this site but I went to an S10 specific website and there retards so figured i'd ask you guys...it still a Chevy...So heres the deal.
--Bought a 2002 S10 v6 4.3 off a buddy of mine with a blown head gasket.
--Took the heads off had them milled, replaced head gaskets with MLS stock replacement gaskets, new head blots all new upper and lower intake gaskets, new thermastat, oil, filter, plugs, wires.. blah blah blah. Everyting came off and went back together great...
--Went to start and it makes a noise but not a normal turning over noise doesnt sound like its firing and it wont start so we checked all the sensors and found the distributor wasn't plugged in..duh ok second try turn the key, same thing..no start same noise..
--Checked for compression... got nothing..0 psi all cylinders
-- i'm thinking pushrods are to long since the heads were milled and the valves are being held open but I figured if they were a little bit to long it would still start just run rough..?
Any help or ideas would be great.
Old 06-13-2010, 04:49 AM
DCC!!'s Avatar
how much was it milled??
it it was a lot you need new pushrods
Old 06-13-2010, 08:27 AM
Ya that is what im thinking also..Tomorrow morning im going to call the machine shop that did the work and see how much they took off.
Old 06-13-2010, 10:41 AM
Z28_LT4's Avatar
May wanna take look at the crank sensor or the wiring to the crank sensor.
Old 06-13-2010, 10:56 AM
01ssreda4's Avatar
New pushrods ftw
Old 06-13-2010, 11:42 AM
LSX Mechanic
Damian's Avatar
If you've got no compression then you're valves are more than likely hanging open due to pushrods being too long. Hopefully you haven't smacked any valves while trying to spin it over.
Old 06-13-2010, 01:01 PM
Would the crank sensor cause no compression?
Old 06-13-2010, 01:05 PM
01ssreda4's Avatar
no......
Old 06-13-2010, 01:15 PM
1badWS6's Avatar
You went to s10forum didn't you? If that's the case then ya you're right ... there's a shitload of **** heads over there.
Old 06-13-2010, 01:20 PM
DCC!!'s Avatar
this is excatly what im thinking you could do a poor mans leakdown test to be sure tho
Old 06-15-2010, 05:44 AM
how exacly do you do this poor mans leakdown test?
Old 06-15-2010, 05:48 AM
crainholio's Avatar
No doubt the other board is not much help, but this topic has nothing to do with Gen-III engine internals.
Old 06-15-2010, 07:08 AM
Old Geezer's Avatar
Rockers moving when you turn it over??
Maybe the "blown h/g" wasn't the only failure.... the timing chain is wadded up????
Old 06-15-2010, 10:52 AM
Ya rockers are moving
Old 06-15-2010, 10:56 AM
01ssreda4's Avatar
But are they closing all the way? Thats the important thing.
Old 06-15-2010, 04:02 PM
DCC!!'s Avatar
the poor mans leakdown test all u need is to blow air into the head and turn it over and see where the air is coming out
i used an old compresion tester that died on me and hooked up a airhose to it and bam
saw it on hp tv
Quick Reply: LSX guy who's s10 wont start..status post head gasket replacement
