View Poll Results: Best Heads for Street Strip Car
TFS 220cc As Cast
9
19.15%
PRC 215cc CNC
13
27.66%
TFS 215cc CNC
25
53.19%
Voters: 47. You may not vote on this poll
Heads Choices? TFS 220,TFS 215 PRC 215?
RHS heads are prty good too. there mid flow numbers are great and thats wat u want think they might b a lil btr or less then trick flows but there cheaper and you can mill them to 37cc huge thickness very strong. i would say its one of the best heads if not the best head out thr for the money. you can take the 500 bucks you save and by smthing to make even more power.
LS1Tech Premium Sponsor
With a MS4 the PRC heads can be setup about 60cc chambers & still clear p/v for the MS4. They will also include a good spring kit so you dont have to upgrade.
With the TFS heads you'll need a spring upgrade to run that lift & best case you can mill them to about 63-64cc.
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Jason
2005 Twin Turbo C6
https://ls1tech.com/forums/dynamomet...0-results.html
I bought the 220's and got the yella terra for less than the 215s and still made great power!
Mario
Mario
dude go to your local speed shop or order these ford racing shims from jegs M-6529-A302. they work perfect and fit perfect...check out my thread hear.
https://ls1tech.com/forums/generatio...me-inside.html
all you need to get the tfs heads to work is .090 worth of shims under the stock rockers to correct geometry and in turn you need to measure for a longer pushrod. weather you go with a thicker pushrod is up to you. again check the thread and see how i did it. also get the trunion upgrade while you at it...not that hard to do with a vice and time time
