Money no object... Best rocker arm out there...
Old 08-24-2010, 12:49 PM
nysbadmk8's Avatar
Default Money no object... Best rocker arm out there...
Pretty simple.
My HS's suck, I cant goto a stock rocker because of my heads, And Im REALLY on the fence about YT's
So Other then Jesel's what else is there?
Old 08-24-2010, 12:52 PM
blsnelling's Avatar
I've heard great things about Comp Cams Ultra-Gold rockers. I have a set of 1.82s on my 5.3.
Old 08-24-2010, 01:11 PM
Old SStroker's Avatar
Originally Posted by nysbadmk8
Pretty simple.
1) What does your head manufacturer (Trickflow??) recommend?
2) What did your valvetrain guy recommend?
3) Money is virtually ALWAYS an object. You could spend upwards of $4K on a rocker system, but you don't need to.
If you don't have a valvetrain guy helping you, look for a good one.
Good luck.
Jon
Old 08-24-2010, 01:21 PM
nysbadmk8's Avatar
Originally Posted by Old SStroker
1) What does your head manufacturer (Trickflow??) recommend? Anything but stock rockers due to valve side loading, but it has been mentioned that a shim kit can cure that issue
2) What did your valvetrain guy recommend? Harland Sharps, which I bought from TEA, they arent working for my combo.
3) Money is virtually ALWAYS an object. You could spend upwards of $4K on a rocker system, but you don't need to. I wont spend 4k, but I will spend whats needed
Who?
Good luck.
Jon
Thank you.
Old 08-24-2010, 01:34 PM
ATwelveSec02Z28's Avatar
You already have your answer...
JESEL
after that T&D
Old 08-24-2010, 01:37 PM
1NASTYZo6's Avatar
This would be my choice.
http://jesel.com/index.php?categoryid=23
Old 08-24-2010, 02:14 PM
nysbadmk8's Avatar
Have you guys used these?
nysbadmk8's Avatar
You might ask airflowdevelop for a suggestion. He's near Harrisburg and posts here.
Jon
I will do.
Old 08-24-2010, 02:22 PM
LS1TECH & Trucks Sponsor
Scoggin Dickey's Avatar
The best and the best for your application are two different things.
stock with trunion upgrade and shimmed for proper geometry
__________________
800-456-0211 / PM / Facebook
WHIPPLE Superchargers, Procharger, Magnuson, Powerbond Sale, HPTuners packages!, Trickflow, AFR, PRC, CHE Trunion upgrade, $100 7.400" pushrod set, Custom Cam of your choice
Old 08-24-2010, 02:30 PM
nysbadmk8's Avatar
Cant do it.. There is still a high risk of premature valve seal wear with shimmed stock rockers with any lift over .550
I am at .637/.647
Old 08-24-2010, 03:03 PM
03supercobra's Avatar
I have a set of Jesels on my car and have had zero problems!
Old 08-24-2010, 03:47 PM
nysbadmk8's Avatar
What do you rev to?
Old 08-24-2010, 03:59 PM
I am at .637/.647
Don't believe everything you read in a mag or online. A number of folks have proved this to be incorrect. Y'all just have to do the valvetrain correctly.
Around here (near the PA border) "you'ns" is more common than "y'all".
Jon
Old 08-24-2010, 04:09 PM
nysbadmk8's Avatar
Jon
Its not out of a Mag, Its straight out of brian tooleys and Mike @ TEA's Mouth.
Old 08-24-2010, 04:41 PM
vettenuts's Avatar
Just curious, you state the HS suck but don't mention any specifics.
Were they set up correctly?
What is the issue with them?
If there is something else that may be the issue then new rockers may not solve whatever your problem is.
Old 08-24-2010, 04:59 PM
What do you rev to?
If the motor made power at 7k i would rev it there, but it only makes power to 6600.
One of my good friends had the same rockers on his motor and would rev to 8k, obviously with the other proper components.
Old 08-24-2010, 05:21 PM
nysbadmk8's Avatar
Too heavy over the valve.. possibly causing float issues over 6000rpm
Old 08-24-2010, 05:37 PM
MIGHTYMOUSE's Avatar
mee too exept stock rockers
Old 08-24-2010, 06:36 PM
I had a set of stockers with the trunion upgrade, but got a STEAL on the Jesels!
Old 08-24-2010, 06:42 PM
redz_02's Avatar
Jon
Come on, you know it's more like "you's guys". Leave the "Yall's" to us southern boys .
If it helps I'll be running Harlands.
Quick Reply: Money no object... Best rocker arm out there...
