Which Head and cam package to buy??
Old 09-30-2010, 07:55 AM
Tony The Tiger's Avatar
Thumbs up Which Head and cam package to buy??
Hello,
I want to buy a head and cam package for my 2001 WS.6 Vert!
I also need advice on a full exhaust package,
I have the SLP muffler now, should I upgrade it?
Tony
Old 09-30-2010, 08:50 AM
Unertl42's Avatar
Vengeance racing is having a sale right now on their heads/cam packages, check in the Sponsors Sale section, and buy some longtubes and I'm sure your stock exhaust is fine
Old 09-30-2010, 09:16 AM
LS1TECH & Trucks Sponsor
Sales4@Texas-Speed's Avatar
It really depends what kind of budget you have, and what kind of package you are looking for. We would also need more info about your car. Is it auto or manual? What else is done to it? If you can answer some of those questions it would be much easier to help you find a package.
Old 09-30-2010, 10:46 AM
It is an 2001 M6 / WS.6 / Convertible (the heavy WS.6, I know)
only thing I did to it is: add a clear MTI lid,
lou short stick and pro 5.0 shifter and also the coolant bypass
I need longtubes, Heads and cam / + tuned.
my budget is around one dollar to $3 grand for now!
but I want 500HP son!
Old 09-30-2010, 11:37 AM
We could do our 2.5 LS6 heads/ Cam package, Pacesetter ceramic coated LTs with an Off-Road Y-pipe, a GM heads/cam gasket and bolt kit, and a mail tune for $2920 before shipping.
As far as cam choice goes, it really depends what you will be using the car for and what you are looking for. Are you looking for a big cam, or something with more mid range and low end power? Is the car your daily driver?
Old 09-30-2010, 03:58 PM
This is a weekend car mostly,
I have a Land Rover (Disco) as my daily driver,
I was looking for a big cam!, sort of like a T-ReX V2! (great loping sound)
I am looking to go for twin turbo for this winter project!
I am still doing some research to make sure I get the most power for the buck!
Old 09-30-2010, 04:57 PM
If you are going to go twin turbo this winter then you should spec the heads and cam towards that. Are you going to stick with the stock motor or build one for those turbos?
I ask this because most big cams with the aggressive idle do not work with turbo kits at all, the actually work against them. For a turbo cam you are looking for a small cam that will get you into boost quickly, and something that doesn't have much overlap to it. Overlap causes the motor to bleed off boost which will rob you of power.
Old 09-30-2010, 05:09 PM
sway99bird's Avatar
Go with texas speed I have got alot of stuff threw them like 4-5 grand I think they are great folks to deal with !
Old 09-30-2010, 05:25 PM
LSX Mechanic
Damian's Avatar
To protect your thread from getting moved I'm going to change the title to "Which heads and cam package to buy". Your title looks like a classifieds ad and it will be moved as such.
Old 09-30-2010, 08:14 PM
Well i guess i need more research but,
I am definately going twin turbo,
(mainly because i had a Dodge stealth RT-TT turbo and wrecked it)
and paid off all my debts, so I have spare money finally!
I just bought the Hooker long tubes 1 7/8 x3" and a Hooker OFY 3"
from Maryland speed,
And so for right now, I just need a heads and cam package deal
to get me over 400rwhp!
There are soo many cam /head choices here for a new enthusiast so i need your advice on a cam non-turbo! for now, because I may scrap the turbo winter project for a moser rear end w/4.10 gears, and baer brakes project $$$
Old 10-01-2010, 08:41 AM
TRANS-DAD's Avatar
Hey tiger, yeah you need to plan your build a little more to save money cause if you are gonna go tw turbo those headers arn'tgonna work either
Old 10-01-2010, 09:12 AM
X-ray's Avatar
Yeah you'll need to ditch the long tubes to put in a turbo manifold. You need to slow down, research, and plan what you're doing before you waste money.
And putting a twin turbo on your Camaro just because your last car was twin turbo isn't very good reasoning. Only put turbos on your camaro if you want that much power. Heads/cam makes plenty power for most people and will still be a hell of a lot faster than a dodge stealth.
And Baer brakes are a waste of money. The stock brakes work great.
Old 10-01-2010, 09:16 AM
SOMbitch's Avatar
Have you even priced a TT setup let alone a single???? Do you have any fab skills because tt's are not a bolton.... If you have to pay somebody even a single will cost you out the a$$..... You need to do a lot of research and really think your build through.....
Old 10-01-2010, 09:46 AM
Yeah, you guys are right!
I will just get The Head & Cams for now!
Old 10-02-2010, 09:12 AM
Ok John, I just jumped on the sale with the free coating with the order of 1x 1- 7/8 KooK's headers W/3" ORY!
so now, I am just looking for 500RWHP with a head and cam package deal!
and a Fast 90/90 setup!
I see you have a "tsunami package?" will the get close the to 500RWHP?
Tony
Old 10-02-2010, 10:24 AM
9secondsflat's Avatar
buy 3000 worth of gold coins today from merit financial...wait 6 months and sell them for $5,000 then spend your money...
my .02 tfs 215 is the only way to go...
Old 10-02-2010, 10:29 AM
eamador11's Avatar
You should get my setup!
Old 10-02-2010, 11:13 AM
SOMbitch's Avatar
Tony
Here is how to get 500RWHP out of a 346. I recommend more ci....>>>>> https://ls1tech.com/forums/generatio...heads-cam.html
Old 10-02-2010, 02:41 PM
fatmat80's Avatar
search tony mamo and you will find is 500 whp thread for a ls1. there have been a lot of guys to do it but it is not cookie cutter. good luck. if it were my proect i would go with afr or tfs heads, fast intake, 230s cam, 1 7/8 american racing headers and ory, e cutout, e water pump, underdrive pulley, 410 gears, speed density tune for a solid chance at the mystical 500rwhp mark.
Old 10-02-2010, 03:13 PM
chrs1313's Avatar
word...
We have alot of stuff in common to achieve the big 500 number...
although i did fall short , junk as a4
Quick Reply: Which Head and cam package to buy??
