View Poll Results: Which Cam
Voters: 33. You may not vote on this poll
Need help finalizing cam choice!
Hey guys, i need a push in the right direction as Ive been in the market to swap out my comp 224/224 .581/.581 114. My car is a '00 WS6 M6 ls1 intake and untouched 241s stock 10bolt with 3:42. Current power numbers are 380/365.5 through random techs and LM1. I'm happy with the cam but im getting bored with it i want something bigger with more lope that 114 doesn't chop hard to me anymore not that it really did to begin with. Looking at these cams...
TSP Torquer 2 232/234 .595/.598 112
TSP Torquer 3 231/234 .643/.598 111
TSP 233/239 233/239 .595/.603 112
Speed Inc Si5 231/237 .589/.595 112
Pat G 232/234 .600/.602 112+4
Any suggestions?
I know theres countless threads on this and believe me I've read them all. Will there even be much noticeable difference from the 3 TSP cams and the Speed cam i listed? That T3 has a high intake lift and I've read in previous threads it can kill springs. I will be upgrading to PRC duals and have 7.4" PR's from my current cam that i will be measuring to see if i need another set. Future mods will be a FAST intake and as for heads those will be the last thing i do since they cost the most and right now i only have money for a cam. Im open to opinions whether negative or positive i just cant finalize my choice... Car sees 1-2K miles a summer i only insure her 6 months out of the year and want to start taking her to the track. Thanks again guys i look forward to hearing the responses!!
Any suggestions?
Thanks for the quick reply. I have a friend that DDs an MS3 and it isn't a problem at all to him. I on the other hand don't daily my car I just don't want to 100% lose all my low end and want this to be my last cam swap so I am trying to take it all in. Thanks again!
Keep em coming. 99blu would those smaller durations be better? I don't wanna change my cam for just a few hps then the money spent doesn't seem worth it
I write checks with my mouth that my ass can't cash
my buddy really suggest the Tv.3 he has the v.2 and loves it, he said the Tv.3 would be even better, i also talked to texas speed and they have put down 425 camonly with the tv.3 on a 6 speed car, all while maintaing a good curve...i would put a fast on it while ur at it
Since you're using stock 241's, what about the old Predator reverse split 232/228 on 108lsa? Hard lope & plenty of low end.......https://ls1tech.com/forums/generatio...side-coin.html
I have 241s. Now but eventually will ditch those for an aftermarket set. Thunderstruck haha I know what u mean that's why I can't decide. I don't think there's gotta be much difference between the cams I listed
I'm really leaning 233/239 unless you guys have any downsides to that cam. When I eventually do heads will PtoV be a problem with this cam or the T3
Why not use/save the money for the supporting mods first like your intake, suspension work, or exhaust depending on what you have done. Especially since you already have a cam in the car. Why spend money where money has already been spent. You would see a lot more benefits getting the car breathing and hooking better then just upping your duration and maybe your lift a little bit.
Cam choice?
I have a 2010 6.0 hybrid that I am going to carb it with the MSD setup. I know I have to change a few things one of which is the cam. My question is what is the best one to use with the carb setup. I will be using the car for street/strip and would like to get 400-450 hp with a fairly smooth idler. It will be going in a 66 Nova.
Thanx,
B
Thanx,
B
ProMaro I will be adding a FAST intake a little bit after the cam upgrade and I do agree with you I've tossed the idea of saving for heads and keeping the cam but it will not get me to where I want to be hp wise (sound wise) even though that isn't everything it's still a deciding factor for me.
