Factory cams
Fbody LS1 cam '98-00:
202/210 intake/exhaust degrees duration
.496/.496 inches lift
116 LSA
Fbody LS1 cam '01-02:
198/197 intake/exhaust degrees duration
.466/.478 inches lift
115 LSA
Ybody LS1 cam '97-01:
198/208 intake/exhaust degrees duration
.500/.500 inches lift
115.5 LSA
Old LS6 cam:
207/217 intake/exhaust degrees duration
.525/.525 inches lift
116 LSA
New LS6 cam:
204/218 intake/exhaust degrees duration
.551/.547 inches lift
117 LSA
GMPP Hot Cam:
218/227 intake/exhaust degrees duration
112 LSA
GMPP ASA Cam:
226/236 intake/exhaust degrees duration
110 LSA
GMPP Grand-Am Cup Cam:
239/251 intake/exhaust degrees duration
.570/.570 inches lift
106 LSA
RPM range: 4000-7000
TR224 Cam:
224/224 intake/exhaust degrees duration
.561/561 inches lift
114 LSA
Comp Cams
218/218
.563/.563
114 LSA
MTI B1
221/221
.558/.558
114 LSA
MTI T1
221/221
.558/.558
112 LSA
MTI C1
222/222
.566/.566
112 LSA
MTI C2
224/224
.581/.581
112 LSA
MTI X1
230/227
.591/.571
112 LSA
May I sugest the "Grand-Am Cup" Cam?
116 LSA
115 LSA
115.5 LSA
Old LS6 cam:
116 LSA
New LS6 cam:
117 LSA
GMPP Hot Cam:
112 LSA
GMPP ASA Cam:
110 LSA
106 LSA
TR224 Cam:
114 LSA
Comp Cams
218/218
.563/.563
114 LSA
MTI B1
221/221
.558/.558
114 LSA
MTI T1
221/221
.558/.558
112 LSA
MTI C1
222/222
.566/.566
112 LSA
MTI C2
224/224
.581/.581
112 LSA
MTI X1
230/227
.591/.571
112 LSA
SN95 Director
these are the actual stock ls1 cam specs on the fbody as spec'd by comps
stock 98 trans am cam
duration@.050 198.86 intake 209.25 exhaust
lift .498 intake .497 exhaust
LSA 119.45
stock 02 trans am cam
duration@.050 196.37 intake 208.72 exhaust
lift .464 intake .479 exhaust
LSA 115.92
LSA 119.45
LSA 115.92
Well in the GM 2001 Camaro/Firbird "F" Shop Manual, it specs the cam at 0.274 intake and 0.281 exhaust. After you multiply by 1.7 you get 0.466 intake and 0.478 exhaust. I don't know what GM's manufacturing tolerance is, but if they are like Thunder Racing the actual lift could vary +/- a couple of thousandths. No mater how you look at it though, this cam is just too small IMO. I think I'll go back and change my original post from .478 on the intake to .466 so I'm not spreading bad information.
Originally Posted by Bads02Z28
It looks like pre 01 cars had better cams. They have more lift and durration. A stock pre 01 cam migth make more power in a 01-02 car than an 01-02 cam.
I you're thinking about a cam, the one I have is a very good street cam. If you don't have to pass emissions or worry about idle quality, I sugest the MTI X1 or Thunder TR230, or something else in the 230 degree range.
Thanks guys for all the responces. I'm thinking about a Z06 cam for now. Eventually I want a nice lopy cam that will give me power with good road manners. But that will wait for heads.
SN95 Director
Originally Posted by Cal
Changing a cam is a lot of work to do twice; I'd just get a TR224 114 cam and be done with it. It will idle very smooth with a good tune. Z06 cam is a bit low on duration IMO.
Questions on valvetrain. I have a 98 f-body and seems power is going flat around 5000 rpms. I know the 98's have a bigger cam. My question is im fixing to install a ls6 intake, Lt's with ory and exhaust system. Also get rid of egr and cats. Should I install valve springs? will it help or are the cams going pertty much flat at those rpm's. It also has a M6
