DO NOT try this at home . . . AKA my BUILD thread :)
Old 01-24-2011, 04:32 PM
Duffster's Avatar
Default DO NOT try this at home . . . AKA my BUILD thread :)
Imagine if you will, a pair of guys inside a large cavern of a garage, hovering atop the engine bay of an 01' Camaro. Engine block visible between them, begging for reconstruction... If the temperatures are sub-freezing and you're attempting to test your p-t-v clearances, DO NOT use the 'tootsie-roll' method. Now, before you say "Duhh!", an effort to thaw the tootsie-roll to ensure it's soft was made. Microwaving the candy before placing onto the face of the piston worked just fine. It's the time between placing it, dropping the piston in the bore, installing the lifters, heads, pushrods . . . . Once the heads were cinched down and the engine rotated, a unique shatter/crack sound was heard. I didn't take pictures (sorry), but just imagine loads of little brown shards floating around in the bore....
Vacuuming was promptly commenced, lots of acetone followed by blowing it out and then re-oiling the bore. . .
Next up, modeling clay!!!
Old 01-24-2011, 05:11 PM
joe77's Avatar
i lol, good luck with the modelling clay
Old 01-24-2011, 05:21 PM
SVThuh's Avatar
How about a space heater blowing hot air on the motor from the bottom?
Old 01-24-2011, 05:26 PM
SSmoked1's Avatar
Guess that means your PTV was zero.
Old 01-24-2011, 07:52 PM
usmcz28's Avatar
Haha now that is funny ****
Old 01-24-2011, 09:43 PM
trans_am7935's Avatar
i think you just put put the piston in upside down, now didnt we learn from the FORD 4.6 modular motor that we don't install pistons upside down...
Old 01-24-2011, 09:45 PM
xX-Z28-Xx's Avatar
You should of got a video and posted it. Lol
Old 01-25-2011, 01:14 AM
LilJayV10's Avatar
I swear to god I just laughed my *** off...mainly because I could see the same thing happening to me.
Post up with results!
Old 01-25-2011, 01:31 AM
00MaroonZ28's Avatar
I didn't know tootsie rolls are used for that. Modeling clay will work much better.
Old 01-25-2011, 06:05 AM
LS1C5Vette's Avatar
I still have the clay peices from my PTVC check 2 years ago sitting on my shelf, lol
Old 01-25-2011, 08:32 AM
Duffster's Avatar
Alright... UPDATE with less embarrassment and pictures!
In another effort to obtain initially said PTV, I searched Walmart and found no clay. I did find silly putty and that wall-stick poster stuff thats very similar to clay. Both have no rebound properties that I could find so, I started with the wall-stick poster stuff...
Cleaned the piston face again, just to make sure there was nothing to interfere with measuring. Assembled it again with a pair of pushrods, 4-bolts for the #2 cylinder cinched tight, installed the rockers (1.82 ratio) and rotated several times.
Net result is nearly 1/4" clearance! I thought it was a bit much, so I did the test again and got the same results.
This is the same piston face I've got a pair of valve dimples in using stock cam and stock springs... guessing a missed shift when I initially bought the car caused it (discovered a few months ago during disassembly).
Guess i've got the clearance I wanted
Old 01-25-2011, 04:35 PM
OWN3D BY MY PROF!
Beaflag VonRathburg's Avatar
I find it interesting that the tootsie roll actually froze. I guess I've never been anywhere cold enough to have a point of reference though.
Old 01-25-2011, 06:08 PM
JPH
JPH's Avatar
What's the cam profile in this car?
Old 01-25-2011, 07:14 PM
Blklsxws6's Avatar
This reminds me of trying to use JB Weld outdoors in the winter. Within seconds of being in cold weather, you suddenly end up with a dark brown rock lol.
Old 01-26-2011, 08:12 AM
Duffster's Avatar
Lunati 55008 spec'ed to .595/.595 237/242 but mics at .600/.601 with 1.7 rockers. I forget the exact, but w/the 1.82's I think it's about .642/.643.
Yeah... it was either in the teens or singles in my garage... IN the garage
Old 01-26-2011, 09:44 AM
Mart00SS's Avatar
is your lifter being compressed when you turn the motor over? I would think that cam would be a little closer to the piston. A lot of times people will use a "test" spring on the valve that is weak so it doesnt compress the lifter.
like so....
Old 01-26-2011, 11:31 PM
LS1C5Vette's Avatar
^Thats what I would use, always check PTVC with a solid lifter or checker springs
Old 01-26-2011, 11:37 PM
nodrok's Avatar
That was funny. Would be a classic scene for a movie.
Old 02-07-2011, 02:35 PM
Duffster's Avatar
Alright, I've spent a few hours here and a few there working on preparing this car for everything I want done. I've routed the cable for battery relocation, degreased and scuff sanded (some wire brushing too) of the k-member, lower control arms and painted them.
Original. . . . :
Now. . . . . :
Went with a dark metallic grey I like the contrast of with my black car.
Wanted to do a degree check on the camshaft (Lunati 55008) and didn't like the prices on degree wheels!!! Made my own
Got my dial gauge ready to go
I've retitled this thread my 'build thread', so enjoy, suggest, criticize and encourage at will! ! !
D
Old 02-07-2011, 04:55 PM
chrs1313's Avatar
there is no way you have that much clearance with that cam...you cannot use a regular lifter unless you have a checker spring...you collapsed the lifter when checking...you have to use a solid lifter and adustable pushrod when using the dual springs
you will be around .060-.070 with stock unmilled 241s and that size cam using stock gaskets...
and tootsie roll ha, just go to a craft store and get clay...or better yet get a dial indicator and you don't have to mess with that stuff
Quick Reply: DO NOT try this at home . . . AKA my BUILD thread :)
