Why LS7 lifters?
Why LS7 lifters?
Why should I upgrade to LS7 lifters in my car? Just ordered cam, springs, pushrods, timing chain and under drive pulleys. Havent't ordered headers yet, trying to decide which brand to get.
LS1Tech Premium Sponsor
It's not an upgrade over your stock lifters. The only advantage they have over buying standard lifters from GM is that they are packaged as a set of 16 for A LOT less money than buying singles.
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
They are the same, for all practical purposes, as your stock lifters. These engines are starting to get higher mileage on average, so people are replacing lifters more frequently now.
__________________
LS7's are the new LS1 lifter. Only difference it bowl size so you may need a touch shorter pushrods, but you need to check. Just wondering are you doing just a cam install? If so, why replace lifters if you don't have to pull the heads..
No, I'm not doing a cam install. I'm trying to track down a nasty noise, and I seem to have it narrowed down to lifters. I didn't mean to hijack the thread, but I figured I jump into an existing discussion rather than start a new one just to clarify one thing.
I'm keeping everything stock, so I was just trying to confirm that I was on the right track. Sounds like the LS7 lifters are the stock replacement, but I may need pushrods (depending) and I'd like to replace the guides as well.
But would I order LS1 guides or LS7 guides?
Thanks all.
Thanks all.
I'd replace the stock trays with LS2 trays while you're there. The new style trays feel noticeably stronger/stiffer, and are cheap insurance against lifters turning!
http://www.texas-speed.com/p-222-gm-...ter-trays.aspx
__________________
The overall height on a ls7 lifter from the roller to the bottom of the cup is the same height as an ls1 height. When you put them side by side they appear to be a different height because of the cups and the bodies of each lifter but this has already been a busted myth....they are the same overall height and use the same lifter length for a stock setup.
I thought the reverse was true: they appear identical length when placed side-by-side, but in reality the cup position is different. So in effect they appear same length, but behave as if different in length.
But this is why I like to ask. Just because something is said often doesn't make it true.
I thought the reverse was true: they appear identical length when placed side-by-side, but in reality the cup position is different. So in effect they appear same length, but behave is if different in length.
https://ls1tech.com/forums/generatio...1-lifters.html
And these are the threads that I recently read through that led me to believe there is a slight difference between LS1 and LS7 lifters:
https://ls1tech.com/forums/generatio...er-length.html
https://ls1tech.com/forums/generatio...-question.html
But the one question that remains unanswered for me is: Even if the difference is small, it could obviously affect the proper functioning of the motor--Why would GM offer this as a direct replacement without comment or mention of the need to check the preload?
