HELP. need a means to control rev limit through spark and not fuel
Old 02-10-2012, 02:20 PM
godspeed01's Avatar
Default HELP. need a means to control rev limit through spark and not fuel
Hello.
im drifting with my a ls1 motor in a 240sx.
Im bouncing off the rev limiter at times and i need a way to cut spark instead of the OEM fuel cut which can lead to lean conditions.
thank you very much i have used the search bottom and could not find anything.
Old 02-10-2012, 02:45 PM
sepsis's Avatar
Get a MSD rev control.
http://www.thunderracing.com/shop-by.../Rev-Limiters/
Old 02-10-2012, 04:42 PM
Moderator
jimmyblue's Avatar
You could just work your spark table to start pulling back
spark, hard, above your desired RPM. But that stands a
good chance of loading your exhaust with unburnt air /
fuel. In concert with the regular fuel-cut though, the spark
could be punked enough to ensure no spark knock. As long
as you are below the diesel limit anyway.
Old 02-10-2012, 04:59 PM
chrisfrost's Avatar
Yes and if for whatever reason You're spark is cut back but not the fuel You're exhaust will fill with fuel/air and then when spark restores there will be an explosion in You're exhaust that often is powerful enough to blow the muffler/mufflers open or possibly blow part of the exhaust off completely .
Old 02-10-2012, 10:32 PM
godspeed01's Avatar
good point with blowing the exhaust off but better exhaust system blowing up than the motor. Thank you guys so much for the information.
I'll give this box thing a try
heres a quick video of her in action.
sorry its so dark you gotta maximize the screen to view it better
720p also works good
http://www.youtube.com/watch?v=FmRjM_DAqRs
Old 02-10-2012, 10:39 PM
godspeed01's Avatar
1 more quick questions. that link pulls up 3 systems, the 2 step, 3 step and the ls series 2 step launch control.
The one i need to get is the LS series 2 step launch control correct ? thank you guys so much, your the best.
Old 02-11-2012, 12:08 AM
bww3588's Avatar
The 2 step launch control will give you a clutch in/trans brake setting and a high limit setting. If your drifting, you obviously won't use the launch control, but the high limit will be what you need.
Old 02-11-2012, 12:14 AM
godspeed01's Avatar
i would rather use the cheaper 89$ 3 step box but i dont know if its compatible with the ls style individual coils. Thats the only issue. If those work i would be happy with one of those due to more adjust ability.
Quick Reply: HELP. need a means to control rev limit through spark and not fuel
