worn ms4 cam
Old 02-20-2012, 07:15 PM
ep142's Avatar
Default worn ms4 cam
I had a TSP 224 for several years and decided to change to the MS4, my car has 36k on it. I only put less then 600 miles on the cam when I heard a very bad valve train noise, I looked threw the cam hole and saw that the lifter did not spin. I have not removed the lifter yet and was wondering if anybody has seen this, I have seen many stock truck engines do this at work.
Old 02-20-2012, 07:21 PM
msydow's Avatar
how many miles on the lifters?
Old 02-20-2012, 07:24 PM
Skypilot797's Avatar
Numerious lobes on a Comp cam 228/232 xer lobe in my LS6 came out looking like that, but the cam had 55,000 miles on it.
It seemed to fall apart very rapidly towards the end. Loud tappet noise started almost overnite. Several lifters had flat spots, but most of the stock lifters did look ok.
Still got the pictures, if you want to see them email me.
Old 02-20-2012, 07:28 PM
ep142's Avatar
they are the orginals with 36k, bought the car with 22k back in 02. had a 224 cam in it for many years with no issues........ Just my luck might go FI now.
Old 02-20-2012, 07:32 PM
91sonomast's Avatar
I've seen quite a few issues with TSP cams lately. Strange.
ep142's Avatar
my noise started just like yours, drove it to work and then to lunch and the damn noise started. Looking threw the cam hole the lifters appear to look good but with out pulling them not 100%.
I would like to see your pics.
Old 02-20-2012, 07:34 PM
ep142's Avatar
that is not good.
Old 02-20-2012, 07:40 PM
ls1wallen's Avatar
Tsp does not make there cams, they spec them out for comp cam to grind.
Old 02-20-2012, 08:18 PM
1999BlueTA's Avatar
^^ Correct!!!
Old 02-20-2012, 08:26 PM
91sonomast's Avatar
Yeah not saying TSP is not doing it right but, a couple weeks ago a guy posted up 3 or 4 TSP cams with messed up lobes. But TSP needs to get these cams in house and inspect them and see what's up before their name gets tarnished.
Old 02-20-2012, 08:46 PM
Sales1@Texas-speed's Avatar
If your having abnormal wear I can assure you it is nothing we are doing, our cams are ground by Comp just like many of the other vendors on this site. If you are having a problem give us a call, and we will do our best to get to the bottom of the situation.
Old 02-20-2012, 08:50 PM
Prorac1's Avatar
IMHO, looks as if a factory roller lifter went south and scared the cam lobe. Eric L
Old 02-20-2012, 09:22 PM
sepsis's Avatar
Chinese cores man.
Old 02-20-2012, 10:20 PM
Blk98Vert's Avatar
Seriously you can't blame TSP. That's like if you got a bad set of 02 sensors from autozone. Would you say autozone makes shitty sensors? No. So why bash TSP?
Old 02-20-2012, 10:21 PM
91sonomast's Avatar
I don't think anyone is bashing TSP.
Old 02-20-2012, 10:36 PM
sepsis's Avatar
Comp cams are always takin ***** on all cars.
My SBC comp cam took a **** and a couple of lobes got wiped. It was a 292H.
Old 02-20-2012, 10:51 PM
RonSSNova's Avatar
That's a flat tappet cam. (292H) How can you compare that with a roller?
Old 02-21-2012, 02:39 AM
sepsis's Avatar
Just saying that no matter what comp cams cam it is, it's gonna take a **** sooner or later.
Old 02-21-2012, 05:58 AM
cranny's Avatar
You really don't hear about this problem that often. It's more of an isolated incident. If this happened more often, the forums would be flooded with posts like this.
Old 02-21-2012, 06:07 AM
supersick99z's Avatar
My buddies cam looked the same way when a lifter went south! You can send damaged cams to Comp to be reground for $125
Quick Reply: worn ms4 cam
