first start after heads and cam
Old 05-23-2012, 10:42 AM
musclecarsrock68's Avatar
Default first start after heads and cam
i just put some 799 heads and a 610 lift cam in my car and got to start it last night for the first time. it seemed to run great off idle and sounds 100 times better now but it wont idle at all. i have herd you have to drill out the hole in your throttle body, if so how big?
Old 05-23-2012, 11:07 AM
03Sssnake's Avatar
Do not start drilling holes in your throttlebody. You need someone to tune the car and set the idle. In the interim you could adjust the idle/throttle stop screw to open the blade and let a little more air in.
Old 05-23-2012, 11:18 AM
gs462's Avatar
Absolutely dont touch your TB just have the car tuned you are moving ALOT more air than the computer is calibrated for. It needs to be re calibrated.
Old 05-23-2012, 11:24 AM
conan's Avatar
Originally Posted by musclecarsrock68
i just put some 799 heads and a 10 lift cam in my car and got to start it last night for the first time. it seemed to run great off idle and sounds 100 times better now but it wont idle at all. i have herd you have to drill out the hole in your throttle body, if so how big?
Go get your car tuned.
Old 05-23-2012, 11:32 AM
alright thanks for the info!
Old 05-23-2012, 12:29 PM
Rise of the Phoenix's Avatar
Out of curiosity, what's the cam specs?
Old 05-23-2012, 06:36 PM
236/240 601/608 113+4 lsa
can anyone tell me what the +4 means?
Old 05-23-2012, 07:43 PM
dam, just realized i put throttle body not throttle plate. (or what ever the name for the plate that opens and closes is)
Old 05-23-2012, 08:10 PM
Z28SteveA4's Avatar
+4 mean you have 4 degrees of overlap ground into the cam
Old 05-23-2012, 08:25 PM
03Sssnake's Avatar
That is 4 degrees of advance timing ground in, not overlap..That cam has 12 degrees of overlap.
Old 05-23-2012, 08:29 PM
sabersaw30's Avatar
You could try this post no.6 might get you a little idle till you get it tuned.https://ls1tech.com/forums/pcm-diagn...-idle-ls1.html
Old 05-24-2012, 02:39 PM
thanks!
