Anyone checked out Advanced Induction's new Dart/RHS CNC'd head program?
http://www.advancedinduction.com/LSX...ccDartHead.php
Here is the link. Appears that this includes the castings, plus the CNC work, valves, springs, etc. Not a bad price at all. I've always heard that the Dart heads were pretty good once ported. Just curious if anyone else has checked this out or has any thoughts on it. How do you think these heads would stack up against CNC ported 243 castings?
With AI's reputation, I'm sure these things are legit. Just curious if these would yeild better results than their ported 243 heads.
Also noticed this: http://www.advancedinduction.com/LSX...0ccTFSHead.php
TFS heads that they CNC port. If I'm reading it right, it says for the price of $2,195.00, you get the TFS heads, CNC port work, springs, retainers, etc. What TFS heads is it; the 220 or the 215? That price seems too good to be true. Am I reading it wrong?
Did you check out the AI website? $1,745.00 for the Dart/RHS CNC'd heads, aftermarket valves, springs good to .660 lift, steel retainers, etc.
For the TFS heads, $2,195.00, which includes the heads, CNC work, aftermarket valves, .660 lift springs, retainers, etc. Hell, you can't get TFS heads that cheap from any vendor I've seen. I just wonder if they are the 220 as cast version or the 215 version? AI's website doesn't say. I want to hear more on this. Maybe AI will jump in.
The Scammer Hammer
I'm curious as to how the Dart stacks up against the 226 243's. I don't care about peak #'s but rather street performance. That's a good deal though regardless for aftermarket heads.
The TFS you linked to are 230's for a 4" bore and bigger. I forget who puts the LS3 valves in the 220's... It's either TEA or AI. Hell, I'd like to know what AI can do to some 220's.
Still haven't found anything definitive on the TSP "as-casts" yet.
Yeah, I've given up on the TSP as cast heads. Many questions have been asked on this site with very little answers.
I know AI does some work to the TFS 220 heads, but I'm still curious what TFS castings they are using for the 230cc CNC option. I'm kind of leaning toward the Dart CNC heads. I'm sure AI will post up more info once they have it. Right now, their pricing for the Dart and TFS heads is a special they are running.
LS1Tech Premium Sponsor
You should really research and get the whole story before posting stuff like that. Dart shot themselves in the foot, we don't put a big enough bandage on the wound, and that's in a nutshell why they have the reputation in the LS1 community they do.
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
I e-mailed AI about their 223 Dart/RHS heads. I'll see what they say and post up. Anymore info in the meantime would be great.
I also just saw this a couple days ago and was going to start the same thread lol
From what i could gather these are AI's own castings that are based off of the Trickflows which is why they are so cheap. And i am also very intrigued with the RHS/Dart heads, the flow sheet listed has them flowing a little bit more than the 226 243's AND they are only a 223cc intake port. Arent these heads supposed to have a pretty thick deck as well? sounds like a good head to me, wouldnt mind seeing some real world results though
I ran Dart 205's for a couple of years problem free. I removed them in favor of the AFR's that were worked over by Tony. I had no issues with the heads and there are a few porters out there who love them although I have read of some valve guide clearance issues in the last couple of years, which may be the reason AI is providing all the parts. They may be buying the castings from Dart and starting from there.
I think you're right; AI is using the Dart 205 castings and doing a CNC port job to get them to 223cc intake and then adding their own valvetrain components. What I like about the Dart castings is they are an aftermarket casting with a thicker head deck and if AI is using them, then I know they are legit and will make great numbers. AI would not get involved with something they didn't think works. From everything I've seen, AI is a great company who knows what they are doing and consistently puts out great products that produce great results. The big question for me is how do they stack up against ported 243 heads? I can see the Dart heads benefiting guys who don't already have the 234 castings.
Phil at AI got back with me and confirmed that these are the Dart/RHS 205 bare castings that are CNC'd by AI to 223cc and include the different valvetrain options. Phil said all these heads are sold exclusively through RHS, so they have the RHS logo cut into the end of them. Phil goes on to say the Dart/RHS 223cc heads were done as a private label for another company years back as something that would be equivalent to their 226cc CNC'd GM 243 heads. So, it sounds like they will yeild similar results. I checked out the flow data and the Dart/RHS 223cc heads flow more than the AI 226 CNC'd GM 243 heads. One big benefit I see in the Dart/RHS heads is the extra thick deck surface. Plus, if you don't have 243 heads laying around, it looks as if this option ends up being a little bit cheaper. Opinions anyone?
