Is a Cam worth it without a Converter?
Old 08-03-2012, 04:48 PM
jpee's Avatar
Default Is a Cam worth it without a Converter?
I have an 05 (C6) it has KOOKS Headers, and a Vararam CAI, + a Tune by Cartek.. The car is automatic (A4) with 3.15 gears...
It has run a best ET of 11.98 @ 117 mph... I know the 05's are known for weak rear ends, so I'm hesitant about putting in a 3200 converter... but would I see an "Meaningful" gains in ET if I just go for a good cam... I know I cant go to big because of my stock converter, if I did go for a cam any suggestions ... keeping in mind I'm using a stock converter and drag radials (best 60' is 1.84)
Thanks
Old 08-03-2012, 04:51 PM
retired cop's Avatar
If my car ran 11.98 I would be dancing in the street !!
Old 08-03-2012, 04:52 PM
thunderstruck507's Avatar
Not for me. Cam isn't worth the cost and trouble unless your going to make best use of it with a bigger cam than will work with the stock converter.
Old 08-03-2012, 05:01 PM
jpee's Avatar
YES I am willing to go to a big cam, but just want to keep the stock converter...I know if I go TOO big, I'll have to put it in Neutral at stop lights, & it will "bang" when I put it in gear...
Old 08-03-2012, 05:14 PM
Sales1@Texas-speed's Avatar
A converter is one of the best mods you can do for an auto car. Especially for someone looking to do a cam swap.
Old 08-03-2012, 05:20 PM
Whiteaw57's Avatar
Okay im gonna get flamed for this because I have an m6 camaro lol but my general knowledge makes me think with some driving sense you won't hurt the rear putting a stall in. And you dont have to go to a 3200 right off the bat. Maybe put in just enough to install a small cam in as well. In my head Im thinking 2500-2800 and something like a 228/232 112-114lsa or maybe even 224/230 112-114 lsa. Just think about it. I have a feeling if you install a converter you may not even need a cam to blow your goals out of the water and keep you happy until you need more.....then youre set for a cam! see what I did there?
Old 08-03-2012, 05:33 PM
usnfenix's Avatar
if it were me and i was looking for gains, but wanted piece of mind, i would bite the bullet and upgrade the rear end first. then put in you choice of stall and cam.
Old 08-03-2012, 05:36 PM
sweet99ss's Avatar
It's really not even worth asking this question in here...
https://ls1tech.com/forums/generatio...ore-stall.html
https://ls1tech.com/forums/generatio...converter.html
https://ls1tech.com/forums/generatio...erter-car.html
https://ls1tech.com/forums/generatio...stall-not.html
https://ls1tech.com/forums/generatio...convertor.html
Old 08-03-2012, 10:49 PM
Fbodyjunkie06's Avatar
You have to get a converter for any type of cam that is worth even spending the money and time to swap to an aftermarket cam.
Do it right.
Old 08-04-2012, 12:24 AM
wildcamaro's Avatar
yes and no...yes you pick up bc of cam but you don't get the full potential either
Old 08-04-2012, 12:35 AM
Detoxx03's Avatar
If you can't do a converter then don't do a cam
Old 08-04-2012, 12:41 AM
BriancWS6's Avatar
I'd do just a converter before just a cam.
Old 08-04-2012, 12:46 AM
sepsis's Avatar
Yep.
That'll be my next mod before a cam.
Old 08-04-2012, 12:59 AM
sukebe's Avatar
Converter first...
Old 08-04-2012, 01:13 PM
NVR_SPDS's Avatar
Get a converter and skip the cam for now. I'm running a heads/cam/SS3600/built trans in my 01 WS.6, with the stock POS 10bolt, and I beat the hell out of my car. I doubt your rear is as weak as my crap rear.
In my personal opinion, I'd go stall and leave the engine stock. I feel that a stall is one of, if not the best mod you can do to an auto! You can stay on the smaller side, around a 3000-3200 and have your rear end survive.
Old 08-04-2012, 03:58 PM
mjs1012's Avatar
i have just a converter without a cam and it drives fine. youll get much more use out of just having a converter than just a cam. the car will want to push through the brakes and will be an absolute dog in the lower rpms.
Old 08-04-2012, 05:37 PM
kinglt-1's Avatar
Running a FTI 3800 here with boltons only...meaning stock heads/cam/intake. Best mod I have ever done to my car next to the kooks 1 7/8 race headers and true dual exhaust. The converter should be the first mod done!! I thought about doing a cam with stock stall, but Im GLAD I didnt!!
Old 08-04-2012, 06:00 PM
FTI makes a great converter.
Greg does all of his stalls to order and none of them are off the shelf.
Although I think he did make a deal with Jegs to sell some pre-made off the shelf stuff, but 90% of his stuff is made to order. Can't go wrong with FTI.
Old 08-04-2012, 06:57 PM
garygnu's Avatar
I would work on reducing the 60 ft time first.you mite find a really mellow cam that mite work with a stock stall.go to comp cams website .
Old 08-04-2012, 10:13 PM
2000PewterT/A's Avatar
