Rear oil barbell plug
Old 10-25-2012, 12:42 PM
mchicia1's Avatar
Default Rear oil barbell plug
Welp got my entire motor put in the car and realized I forgot to check this. So I called the machine shop and they said there was just a big hole back there so they never replaced it because there wasn't anything to replace. I have two questions.
1) What is the proper way to install this thing? Just tap it in? How far? Which side goes into the block?
2) Is there a way to check if it is installed without pulling everything apart? I just find it odd that it wouldn't be installed because this block came out of a running ls1. Someone mentioned removing one of the side plugs and peaking in with a flash light?
Old 10-25-2012, 08:03 PM
moeZ28's Avatar
You can drop the pull the rear cover with the motor in the car but you have to drop the tranny out...Can't picture the orientation of the plug though...been awhile since I seen one but I believe it goes in with the ridges and O-ring to the outside of the block toward the tranny. And it just pops in. A little resistance, but just pops right in.
Old 10-25-2012, 08:20 PM
ABQ99TA's Avatar
Yep pull the rear cover and take a look
Old 10-25-2012, 10:35 PM
mchicia1's Avatar
Got the trans out. Yup, forgot to put the damn barbell plug in. The trans is back in the car. Basically just lost a day, which is better than losing a motor and a month and a lot of money.
Old 10-25-2012, 10:53 PM
Received 3,369 Likes on 2,085 Posts
Nice catch!!
Old 10-25-2012, 11:08 PM
mchicia1's Avatar
Nice catch!!
Thank you. Gotta love the internet. I had some downtime so I figured I would google common issues with ls1 motor rebuilds. Sure enough, a very common problem is people leaving these plugs out and not having oil pressure. This random googling saved my new motor.
Old 10-26-2012, 05:18 AM
Jontall's Avatar
Old 10-26-2012, 08:46 AM
mchicia1's Avatar
Thanks for the picture. We got it in though. It immediately became evident that it was designed to be pressed in and held with the rear cover. So we pushed it in as far as we could then plopped the rear cover on to pull it in the rest of the way.
Old 10-27-2012, 06:12 PM
moeZ28's Avatar
Oh ok...the ridges are to the front...the o-ring is on the opposite end...told you it had been awhile since I saw one.
Old 10-29-2012, 08:17 AM
mchicia1's Avatar
Success. Oil pressure came right up on first start.
Quick Reply: Rear oil barbell plug
