OK to reuse oil pan gasket on new crate engine?
Old 08-05-2013, 08:34 PM
Cobra4B's Avatar
Default OK to reuse oil pan gasket on new crate engine?
Service manual specifically states DO NOT REUSE OIL PAN GASKET. However, I'm putting a C5 pan on a new crate engine for a LS1 GTO (swapping heads/cam as well).
Thoughts on reusing the gasket? It's a nice rubber gasket just like the rest of the LSX stuff.
Old 08-05-2013, 09:52 PM
Russ K's Avatar
First off, a GTO uses a front sump pan, and I would never reuse a oil pan gasket.
Russ Kemp
Old 08-05-2013, 10:05 PM
zzcamaro00's Avatar
its pretty cheap man, your not losing a whole lot of money. better off safe than sorry
Old 08-05-2013, 10:12 PM
garygnu's Avatar
get a new one .how much time and money would it cost to replace it if it leaks in car ?
Old 08-06-2013, 01:24 AM
Burken01's Avatar
If the rubber is still raised and spongy and not flat compressed like a old one off a high mileage vehicle then yes you can reuse it...
Old 08-06-2013, 02:11 AM
PREDATOR-Z's Avatar
Oil pan is not the place I would start by saving pennies. As mentioned above; what if it leaks, how much time/effort and $$ will it take to replace then.
Old 08-06-2013, 02:35 AM
2000PewterT/A's Avatar
Buy a new one its cheap
Old 08-06-2013, 10:24 AM
Cobra4B's Avatar
Russ Kemp
I'm well aware... put on in my father's Panoz. The gasket is the same.
Yep.. it looks just like the brand new one I used on the Panoz install. Not flat at all.
Probably will... don't want a pan leak with the engine in the car.
Old 08-06-2013, 06:39 PM
Russ K's Avatar
Ok, I understood that your installing the engine in a GTO.
Russ Kemp
Old 08-06-2013, 07:05 PM
themealonwheels's Avatar
I'll take the unpopular side and say reuse it if it hasn't been heat cycled. Even if it was compressed, oil pan bolts are only 18ft-lbs. I'm all for being cautious, but if it hasn't been heated up, I would definitely reuse it.
I also must be missing the gravity of the issue, because everyone so far seems to have classified this gasket's failure as an automatic catastrophic engine failure. I immediately think small leak when I think gasket failure on the oil pan, not catastrophic. Am I missing something?
I'd reuse it if it's never been heat cycled.
Old 08-06-2013, 08:00 PM
Cobra4B's Avatar
On a C5 you have to drop the cradle to swap the gasket. I went ahead and bought a new one for $31 at the local dealer. I agree with you that not being heat cycled and just mildly compressed it's probably OK to re-use.
Old 08-07-2013, 03:08 PM
2000ultraZ1911's Avatar
Beings that it came off a new engine I would think its ok...but that far dwn I don't think I'd risk it because even if it has the smallest of leaks when I got it togeather it'd drive me nuts lol but everyone has there own way of sound things.
Quick Reply: OK to reuse oil pan gasket on new crate engine?
