Pulled valve covers... one side is burnt looking??? why?? *pic inside*
Old 08-09-2013, 01:24 PM
FbodyFreak's Avatar
Default Pulled valve covers... one side is burnt looking??? why?? *pic inside*
my buddy has a JY LQ4 we picked up for a decent deal.... we have gotten around to pulling the valve covers off and one side looks burnt~ish everything is just darker in color on the one side.
Any ideas why this happens?
havent pulled the plugs or oil pan but the rockers and pushrods are all darker color????
any info helps..
Attached Thumbnails Pulled valve covers... one side is burnt looking??? why?? *pic inside*-20130809_120654.jpg
Old 08-09-2013, 01:33 PM
Jimbo1367's Avatar
Its a JY motor. They probably replaced the VC due to damage. Maybe a accident or they caused it during removal.
Old 08-09-2013, 01:49 PM
allan808's Avatar
The driver side is the dirty side for pvc the passenger side is the clean air side that hooks up to tb.maybe that is the cause?
Old 08-09-2013, 02:18 PM
99Bluz28's Avatar
The color difference is from the baffling on the top of the drivers side VC compared to the lack of baffling on the passenger side VC.
Old 08-10-2013, 07:51 AM
vettenuts's Avatar
Is is stock or has the PCV system been altered? That is a potential cause if, as stated above, both VC are original and one hasn't been replaced with a new one.
Old 08-10-2013, 08:48 AM
2000ultraZ1911's Avatar
It looks like the clean side has been replaced
Old 08-10-2013, 09:48 AM
98ws6blk's Avatar
I'd say the clean side has been replaced....its crazy clean. The burnt side as you describe it looks normal to me.
Old 08-10-2013, 02:10 PM
Old Geezer's Avatar
"The burnt side"... varnish build up.
Old 08-11-2013, 07:40 PM
sic7camaro's Avatar
I got two motors like that an ls3 and lm7.both looked like they had parts replaced
Old 08-11-2013, 10:23 PM
FbodyFreak's Avatar
hmmm, Idk.... I got the motor from a little service shop, they said the truck was having a small tick. i think it was valvetrain noise from the description(loose rocker perhaps).
Never said that any valvetrain parts were replaced though.
the valve springs, retainers, pushrods, rockers all showed a darker shade on the one side.
Took the plugs out, they were all the same. (no melted, white, etc.)
pulled the heads off, all pistons and cchambers showed identical buildup.
I did notice however a weird pastey, tacky, almost grease like substance in a couple of the intake runners of the heads though (i never seen before). idk
last thing to do is pull the oil pan and do a visual of the rotating assembly.
Old 08-12-2013, 03:33 PM
With that said I guess I'd lean toward PVC....I can't think of anything else....I white pasty stuff I've read that from runnin to cool of a stat and the oil not getting hot enough...
Deff weird keep me posted. Good luck.
Quick Reply: Pulled valve covers... one side is burnt looking??? why?? *pic inside*
