Cost and pieces required to complete a long block.
Old 04-23-2014, 01:45 PM
mitchyrocks's Avatar
Default Cost and pieces required to complete a long block.
Hey guys, I've been lurking around a while and I can't seem to find an answer to this. What are the parts required to turn say, a tsp long block into a complete motor? Would it be more cost effective to buy a long block or a complete motor? Any info is appreciated. Thank you.
Old 04-23-2014, 05:26 PM
Bumpety
Old 04-23-2014, 05:48 PM
HCI2000SS's Avatar
I'm not sure I really understand your question since a long block is basically the complete motor
Old 04-23-2014, 06:18 PM
Do they come with lifters? Do I need a valley cover? The rest of the small stuff that goes in/on it is what I need to know
Old 04-23-2014, 06:43 PM
camaroboy408's Avatar
I believe they come with lifters but not completely positive might call and ask them
Old 04-23-2014, 07:57 PM
HCI2000SS's Avatar
Depends on who you buy from but most that i've seen come with lifters, valley cover, pushrods, oil pump, all gaskets and bolts, etc, etc...
Old 04-23-2014, 08:09 PM
99Bluz28's Avatar
IMO, if you don't have any of the below parts to transfer over to the new engine, you might want to consider a crate motor, but you won't probably have the option to pick-n-choose parts from a option list like you would with a short, or long block. Furthermore, you'll still need to get all your accessories, their mount brackets, plus pulleys.
With a TSP long block you'll need all you accessories and mount brackets plus pulleys, valve covers, valley cover(depends on engine), intake manifold, throttle body, water pump, oil pan, coils an mount brackets.
Please correct me if I left anything out.
Old 04-23-2014, 08:20 PM
CHEVELLEPOSSE's Avatar
Same as blue z 28 said
Old 04-24-2014, 01:33 AM
Super Hulk Smash
JakeFusion's Avatar
Flexplate/flywheel, damper, valve covers & gaskets, valley cover & gasket, intake manifold, throttle body, fuel rails, fuel injectors, front drive accessories (alternator, water pump, power steering pump, idler pullies, tensioner - A/C optional), exhaust manifolds/headers, spark plugs, spark plug wires, ignition brackets, ignition coils, sensors (ECT, IAT, MAP, MAF, O2, knock, TPS), starter, oil pan, oil pan gasket, oil filter, oil, and coolant.
Might have missed something?
Old 04-24-2014, 07:02 AM
Sorry for the confusion, I'm starting a swap into a 350z soon. I do not have an ls motor at the moment. So it looks like I will be chasing an ls2 pullout for now and swapping that because I don't want to have to chase down that laundry list of products
Old 04-24-2014, 09:07 AM
These parts are easy to find and inexpensive when buying used
Quick Reply: Cost and pieces required to complete a long block.
