Lowering CR and Smog
I can't explain it better than this, so here you go...
"Most people know that an increase in Compression Ratio will require an
increase in fuel octane for the same engine design. Increasing the
compression ratio increases the theoretical thermodynamic efficiency of an
engine according to the standard equation
Efficiency = 1 - (1/compression ratio)^gamma-1
where gamma = ratio of specific heats at constant pressure and constant
volume of the working fluid ( for most purposes air is the working fluid,
and is treated as an ideal gas ). There are indications that thermal
efficiency reaches a maximum at a compression ratio of about 17:1 for
gasoline fuels in an SI engine [23].
The efficiency gains are best when the engine is at incipient knock, that's
why knock sensors ( actually vibration sensors ) are used. Low compression
ratio engines are less efficient because they can not deliver as much of the
ideal combustion power to the flywheel. For a typical carburetted engine,
without engine management [27,38]:-
Compression Ratio -- Octane Number Requirement -- Brake Thermal Efficiency (WOT)
5:1 -- 72 -- xx
6:1 -- 81 -- 25 %
7:1 -- 87 -- 28 %
8:1 -- 92 -- 30 %
9:1 -- 96 -- 32 %
10:1 -- 100 -- 33 %
11:1 -- 104 -- 34 %
12:1 -- 108 -- 35 %
Modern engines have improved significantly on this, and the changing fuel
specifications and engine design should see more improvements, but
significant gains may have to await improved engine materials and fuels."
5:1 -- 72 -- xx
6:1 -- 81 -- 25 %
7:1 -- 87 -- 28 %
8:1 -- 92 -- 30 %
9:1 -- 96 -- 32 %
10:1 -- 100 -- 33 %
11:1 -- 104 -- 34 %
12:1 -- 108 -- 35 %
