polluterv2 in a ls1
Old 06-25-2016, 11:05 PM
jrext's Avatar
Default polluterv2 in a ls1
ordered a stage 3 polluter v2 for my 2000 vert. 1 and 3/4 long tubes, ls6 intake, sbe, thinking a 3600 stall, 3:73 gears in an A4 with 853 heads and the btr dual springs.... am i going too big on the cam?
Old 06-25-2016, 11:16 PM
HCI2000SS's Avatar
What are the specs?
Old 06-25-2016, 11:19 PM
jrext's Avatar
Default specs
239/ 244 635/610 on a 112 +3
Old 06-26-2016, 12:06 AM
NAVYBLUE210's Avatar
Location: Coast of San Mateo County Between Pacifica & HMB
If you have to ask....
I think you know the answer is
Yes!
For a Strip/street car (hard top) with a FAST 102
still a very large cam for 346" IMO.
Old 06-26-2016, 12:20 AM
MaroonMonsterLS1's Avatar
Received 1,218 Likes on 782 Posts
If all you want it to do is sound cool and shake the car...you've picked the right cam.
If you don't want to start to make power until 6000 rpm...you've piced the right cam.
If you want a cam that's going to make optimal power under the curve, have usable torque and retain decent drivability, you've picked the wrong cam.
Old 06-26-2016, 12:51 AM
jrext's Avatar
thanks for the input. Matt at tick said this is what i should have. we'll be talking on monday.
Old 06-26-2016, 02:58 AM
1970camaroRS's Avatar
Did you tell him that you rarely drive your car and you wanted a very aggressive cam? Because that's the only way I see him recommending that cam. I'm running the LS2 version (slightly tighter LSA) in a 375" 11.5:1 motor with ported heads and a 102mm LSXrt intake and I'm expecting it to be barely livable as a daily. Even with a 3800 stall and 4.30 gears.
Old 06-26-2016, 06:39 AM
HCI2000SS's Avatar
These guys are right on the money. With your setup a smaller cam will actually be faster overall
Old 06-26-2016, 09:00 AM
jrext's Avatar
I told him that I would like to have 380 to 400 rwhp and some strip runs once or twice a year. We will get it figured out on monday. Really looking for the torque not a high winder.
Old 06-26-2016, 09:07 AM
HCI2000SS's Avatar
This cam will give a great peak number on the dyno, but usable torque not so much lol
Old 06-26-2016, 09:11 AM
kinglt-1's Avatar
Your last post confirms you purchased the wrong cam. The V2 is going to want lots of rpm and going to have substantially less tq down low. A bit of research would of yielded that the sweet spot for a LS1 is in the 228/232 range for all around performance/drieve-ability. The SNS stage 2 would of been my choice for a Tick cam.
Old 06-26-2016, 09:39 AM
jrext's Avatar
Sorry don't know alot about the ls1. That's why I asked the professionals what I need. Have been Reading too much garbage also. Hopefully this will be straightened out easily enough on monday. Again thanks for the input .
Old 06-26-2016, 10:00 AM
whatsa347's Avatar
Here you go
Old 06-26-2016, 11:05 AM
Search my threads and you'll see discussion about my spec for a reverse split grind. Something worth looking at imo
Old 06-26-2016, 11:46 AM
jrext's Avatar
Good info Maroon! Pretty much at the mercy of a tick cam now that I gave him the money lol. The stage 2 sns looks like it will have to be enough for now. I just hope if I upgrade heads or bottle feed it down the road I won't be looking for another cam. Unfortunately the pockets aren't deep enough for this sh*t.
Old 06-26-2016, 11:49 AM
jrext's Avatar
I am like everyone else ....I want a 10 second car on a 12 second budget ; )
Old 06-26-2016, 04:26 PM
MYSTIC-1SC's Avatar
Agreed the performance results with that cam and your particular setup including the 3600 converter just aren't going to perform very well. Give those guys a call again and be honest with them about what you are looking for. I honestly feel like you'll be much better with something in the high 220s low 230s unless you plan to make other changes to your current setup to get it to perform correctly.
Old 06-26-2016, 05:16 PM
jrext's Avatar
Am I out of line in hoping to be close to 400 rwhp?
Old 06-26-2016, 05:21 PM
MYSTIC-1SC's Avatar
Not at all. 400 rwhp can be had with a much milder camshaft than you currently have purchased. Also with a much more usable and practical rpm range for your application/ intended use.
Old 06-26-2016, 05:27 PM
jrext's Avatar
Thanks for the vote of confidence. Been turning this over in my head since I ordered on friday afternoon. Just want a respectable 60 ft time the rest will be there at the end. Now it's time to figure out rear tires and rims.......
Quick Reply: polluterv2 in a ls1
