Is 2.05 on the intake too much?
Old 10-14-2004, 06:33 PM
RedDragon009's Avatar
Default Is 2.05 on the intake too much?
I have a 01 TA M6 and I was wondering when I get my h/c setup would 2.05 on the intake be too much for my 346?
Old 10-14-2004, 07:20 PM
Suspended Sponsor Account
ForceFed HP's Avatar
need more info. what are your plans and goals? while a 2.055 is a bit large for a 346 it is not necessarily to large.
Old 10-14-2004, 08:24 PM
I want to turn the car into a nice street/strip car with all the bolt on's. I would like to be in the mid 400 rwhp range running low 11's. The cam i was thinking of running is a F11 cam.
Old 10-14-2004, 09:59 PM
Paulz2820's Avatar
then yes 2.055 is too big
if your getting a killer deal on them though then i'd do it...but you will loose some low end power and torque. however if you ever go with a stroker or something later on they will work great. consider it getting ready for the big one
Old 10-15-2004, 01:18 PM
reddragon009- sent you a pm
Old 10-15-2004, 02:58 PM
Yellerr's Avatar
I have 2.055 on mine. 1.58 exaust. I like'em. My launches are stronger now. My best 60' is 1.77
Old 10-17-2004, 12:25 PM
Moderator
John B's Avatar
I made 426 RWHP/400 RWTQ using 2.05 intake's and 1.60's on the exhaust with my MTI stage II LS1 heads and a dinky B1 cam so I wouldn't rule out 2.05's too quickly! All depends on the porting work.
Old 10-17-2004, 01:28 PM
cyphur's Avatar
i'm considering using 2.05 intake valves this spring when i look into heads, probably on stg2 ls6's. these will be on my 346 for a while, then possibly be reworked for a larger bore. they will work for the standard 3.9 bore as long as the porter knows this going into the project, and everything is matched well enough. give TEA a call....
Old 10-17-2004, 04:03 PM
M6HuggerSS's Avatar
i was told that the 2.05 will not hurt power but the gain in flow is minimal .....maybe
1-5 cfm differance..... its the porting that can hurt you, not the valves.
Old 10-17-2004, 05:07 PM
CHRISPY's Avatar
2.055 is what most of the top head offerings are using now. With a larger bore (4.XX they typically will go up to a 2.08 to 2.10 valve depending on bore size/application)
Certain S2 designated heads are using 2.02 but most of the all out heads seem to be coming with the 2.055
Personally I would not go smaller than 2.055 on the intake.
Old 12-09-2004, 09:51 PM
M6HuggerSS's Avatar
pics of my 2.05
Attached Thumbnails Is 2.05 on the intake too much?-smallhc4.jpg   Is 2.05 on the intake too much?-smallhc3.jpg
