Which heads to get?
Well, if AFR are worth the extra money, I'll pay it.
My Plan is to go 10's n/a, I'm also looking into a new botton end.
I called SLP today about the ZL-402 and I'm not paying $100 crate fee, $400-500 just Cali, when I'm in Hawaii
I'd like to stay under $6K if possible for everything
A 408 with some Stage 3 TEA AFR's and a FAST 90/90 would do the trick.
I'm not sure on cost/shipping though for this, the heads are around 2900 but they are for > 3.900 bore.
Well, I have Patriot 5.3L Stage 2 heads now, I had some problems, dual springs that came with them one broke after 3000 miles.
The second set that Terry sent for free, I got valve float on #6 and #3 cylinder and the piston hit the valve.
I know of a way to get heavy stuff shipped to Hawaii for $1 per lb. Only problem is is that you have to pay shipping to their location. Let me know if you want me to check into it further.
*cough*lingenfelter*cough*
Originally Posted by nuzee
I have a set of stock rocker arms that you can have if you want.
Thanks, I don't know shipping on that going to be
They were the older bigger diameter springs, Not the gold.
Plus I have the shift points at 6000 rpms
I hope you didn't have too much damage from the spring breaks.
Anyway, I would go with TEA, Absolute (might have to wait 6months to a year for those ), or wait for the AFR 225's, which could make the most power, and are supposed to come out in December or January.
https://ls1tech.com/forums/dynamometer-results-comparisons/208929-prc-225-cam-prc-stage-2-5-5-3-heads.html
https://ls1tech.com/forums/dynamometer-results-comparisons/207313-tsp-magic-stick-prc-heads-a4-dyno-results.html
https://ls1tech.com/forums/generation-iii-internal-engine/208941-new-brand-heads.html
