2003 C-5 What Heads do I have?
Old 12-28-2004, 05:50 PM
Honez's Avatar
Default 2003 C-5 What Heads do I have?
Does anyone know if this car has LS6 or LS1 style heads?
Old 12-28-2004, 06:29 PM
LS1TECH Sponsor
badpewter-z's Avatar
c5=ls1
zo6=ls6
but you do have the better of all stock ls1 castings
Old 12-28-2004, 07:34 PM
~JOSHUA's Avatar
Look at the casting number. 241= good LS1 heads. dat b it!
Old 12-28-2004, 11:00 PM
Honez's Avatar
Looks like I do have the 241's, my quesiton now is should I have these worked up or should I go with a set of the AFR's stage II's or PP stage II's? Are these 241's better to keep and work up?
Old 12-29-2004, 12:13 AM
BlueSix's Avatar
If you have the coin to spend go for the AFR's. If you can't go all out, go for porter LS6 (243) castings, if money is a big concern, get the 241's reworked.
Old 12-29-2004, 12:22 AM
azgasser's Avatar
where do I find the casting number?
Old 12-29-2004, 12:27 AM
BlueSix's Avatar
I believe it's on the lower portion of the head at the front of the engine. I know it's at the front, just not sure where on the head it's located...i've only checked a couple dozen casting numbers, you'd think i could remember. What year is your car? I can tell you what heads you have from that info...
Old 12-29-2004, 01:24 AM
PREDATOR-Z's Avatar
Casting # is at the Passenger side>front lower part (it is also on the other side but under cowl.)
Old 12-29-2004, 11:05 AM
CharlieLed's Avatar
Lower right corner of either head, on a pad just below the valve cover. It will be a 3-digit number. If the engine is in the car then look on the passenger side head, it will be at the front of the engine.
