After cam issues
After cam issues
I recently put in a TSP 231/237 cam with 918's. I got through 3 heat cycles and decided to rev it up Sunday after it got to normal temps. I revved it up and when it came back down to idle, it sounded like it was going to stall for about 4 seconds. Then the idle went back up to normal. I am thinking a tune is needed. I've been told the car was tuned for the TR220 cam that was in it, but I am not 100% sure.
I also smell gas when it is idling. I assume it needs leaned out a little.
Is this common after cam installs?
Originally Posted by smokeum99ta
yep .before tuning my car would just about cut off after reving.tuning made a world of differance.
Originally Posted by 5POINT7
I've got the same cam. It does the same thing after a rev. Don't worry man, you're not alone.
I Drilled My Throttle Body Per Mti After I Installed The G-1 Cam
After I Got My Car Tuned The Idle Started To Hang At 2,000 Rpm On Decel
I Replaced My Throttle Body & Now It Drops Back Down Fine-drilling Is
A Non-tuned Cars Way To An Easy Idle-i Wish I Hadn't Drilled Mine.dude,you
Must Get Your Car Tuned After A Cam Install-you Will Be Amazed At The
Difference.
Difference.
