what heads to get for a 408 forged.. with a procharger
Old 09-08-2005, 04:40 PM
Mr_president's Avatar
Default what heads to get for a 408 forged.. with a procharger
im sure i need low compression heads the question is what size and which ones?? would the stock 6 leader heads be good ?? also..... what kind of fuel system would i need and what would be the cost?
Old 09-08-2005, 10:06 PM
Elite_Hot_Rod's Avatar
AFR's, All Pro's or I've heard that Trick Flow is supposed to be coming out with a nice set of LS1 style heads that flow some crazy numbers. I would buy the best fuel system components I could afford. I'd get either a Weldon system or a Barry Grant system and Aeromotive makes some affordable stuff also.
Old 09-09-2005, 03:54 PM
ArcticZ28's Avatar
The stock LQ9 heads would be the best place to start without spending a shitload of money on aftermarket heads that will make good HP. The LQ9 heads are 72cc which gives pretty low compression for a turbo/super if you are using a typical -15cc dished piston. Might actually want to go with a larger dished piston if you want to run a lot of boost though. If you want aftermarket heads, the AFR 225's would be the way to go, or something along those lines of a higher cc chamber.
Old 09-09-2005, 04:06 PM
JarrettL's Avatar
It's all in your budget.
Old 09-12-2005, 06:54 AM
EPP
EPP's Avatar
Take a look at the Patriot Performance LQ9 CNC'd heads. The heads flow decent numbers, come with titanium retainers, valvesprings that will handle a high lift camshaft, plus head gaskets and head bolts are included. I would use ARP head studs instead though, for your application. Bob
Old 09-12-2005, 07:10 AM
Blown408's Avatar
Contact Brad or Scott at ForceFed High Performance http://www.forcefedhighperformance.com/
They can hook you up! I am going with the ET Performance heads.
Old 09-12-2005, 09:56 AM
ArcticZ28's Avatar
Also search "Patriot Performance heads". You'll love the results everyone has had with their products
Old 09-12-2005, 10:36 AM
JZ'sTA's Avatar
Honestly the heads will vary compression but you just cant go slap a set of heads on any 408. Your going to need a large dished piston to achieve 9:1 or lower compression using a 408 cubic inch motor. You will also need a hell of a fuel system, a highly upgraded supercharger setup with a large head unit. The list can go on forever. Your looking at a 20,000 dollar or more build to do it the right way.
Old 09-12-2005, 10:39 AM
JZ'sTA's Avatar
BTW a typical setup 408 with flat tops and 2cc valve relives will still be around 11:1 compression.
Your looking at somewhere between a 22-25cc dished piston depending on gasket thickness to get the compression down to 9:1 with a 72cc head.
Quick Reply: what heads to get for a 408 forged.. with a procharger
