many cheap NA/N20 heads... what about FI?
Old 09-16-2005, 08:42 AM
7 Second Club
ty_ty13's Avatar
Default many cheap NA/N20 heads... what about FI?
I've noticed many vendors are concentrating on the NA and N20 applications but what about the guys that want a larger combustion chamber/low CR for a sick and cheap FI setup?
seems like to me most everyone in FI is using the AFR 225's...
if im leaving a head out that would be good for FI please inform me.
Old 09-16-2005, 09:13 AM
PREDATOR-Z's Avatar
Yeap any CNC ported,stage 2 or 3 LS6 style LQ9/LQ4 head, without welded chambers.
Old 09-16-2005, 09:20 AM
Blown408's Avatar
ETPerformance.
Here is the thread on my heads https://ls1tech.com/forums/generation-iii-internal-engine/380816-et-performance-flow-numbers-impressions.html
Old 09-16-2005, 09:21 AM
7 Second Club
ty_ty13's Avatar
are they thick enought to hold down under 14+ lbs of boost?
Blown408's Avatar
The ETs have a thick deck on them.
Old 09-16-2005, 09:24 AM
PREDATOR-Z's Avatar
You don't need thick deck for 14lbs of boost. You need studs and good block/head deck prep with a nice set of Cometics.
14lbs of boost is peanuts.
Old 09-16-2005, 09:28 AM
7 Second Club
ty_ty13's Avatar
notice i said +.... 14 would be a good after about 2-3 weeks at 10... I'd like to see upwards of 20.....
i checked TEA's stuff and there 6.0/ls6 stuff is just as much as or close to the price of AFR 225?
are you seeing a different vendor out there?
no PP quotes please... not knocking but there have been issues and i understand people over come them but i want some more assurance before i drop 1200+ on a peice of metal
Old 09-16-2005, 10:29 AM
PREDATOR-Z's Avatar
Yeap, if you're heading 20+ lbs boost then thicker deck is the way to go.
