hyd cam on solid lifter
Old 10-09-2005, 06:04 AM
vtanju's Avatar
Angry hyd cam on solid lifter
what do you guys think about putting a 243-249-114 hyd cam in a solid roller setup. there are mixed view, some say the hyd cam has an agressive ramp which would not be good on solid lifters and some say the opposite that solid cams have a fast ramp. bit confused. can you please shed some light on this matter. considering that this is a race engine and that it will be rebuild frequently, power wise would it be feasable to use this cam. or has anybody done any experiments on this?
thanks
Old 10-09-2005, 08:05 AM
vtanju's Avatar
anyone?
Old 10-09-2005, 08:31 AM
383ss's Avatar
yes, you can do it, but you need adjustable rockers and obviously solid lifters. I'm not sure why you would want to do it, unless you don't have the cash for a solid cam.
Old 10-09-2005, 09:52 AM
Ed Curtis's Avatar
Cool
thanks
You should be able to use a good solid roller lifter on the cam as long as the core is billet but...
Why not just use a set of Morel hydraulic roller lifters, the right spring package and adjustable rockers? Good for more RPM than you can imagine!
Ed
Old 10-09-2005, 10:23 AM
vtanju's Avatar
thanks for the reply
i have the morel solid roller lifters and crane 1.8 adjustable rockers. what do you think? should i go with this setup or purchase bigger solid roller cam. my opinion is that this setup will be better. i am also using 250hp nos.
thanks
Old 10-09-2005, 10:33 AM
Ed Curtis's Avatar
Cool
thanks
I'll get in trouble with the "boyz" in here for saying this but I'd do a new solid roller profile...
With the increased rocker ratio, you'll want something designed with that in mind...
<ducking for cover> ........
Ed
Old 10-09-2005, 10:45 AM
RDTA's Avatar
actually I was reading about doing the exact samething in the newest hot rod mag. I think that was what it was, they (COMP) said you could do that but you had to be real careful with the lash on the rockers you may want to find that book and read the articall. had alot of info on doing this and putting HYD s on a solid roller cam.
Old 10-09-2005, 12:01 PM
383ss's Avatar
ya, they say if you have an aluminum block and heads, its really hard to get it correct.
Old 10-09-2005, 12:10 PM
vtanju's Avatar
i have just started the car with 243-249-114 hyd cam on a solid roller setup with 1.8 ratio rockers, done the lashing, and the car revs like crazy above 4000rpm. low end power and torque in my opinion are excellent. too bad we dont have a dyno here that can measure over 400hp, but the car feels very good. its like it wants to rev to 8000rpm . but i still want opinions on, if i should use a real solid roller cam such as 250-260-114 with about 0.600 lift with 1.7 rockers. my setup is 435LS1 extreme lightweight assembly, ported heads 255cc, FAST90mm, custom made headers larger than KOOKS, drysump.
Old 10-09-2005, 02:26 PM
vtanju's Avatar
anymore opinions?
Old 10-09-2005, 02:52 PM
DONAIMIAN's Avatar
.600 with a solid roller setup is low lift. Most on here have something in the .700+ range. If the bottom end is built, and it has a dry sump, I say take it up as high in the RPM range as you feel comfortable.
