? 124k miles on stock rockers and lifters should they be replaced?
Old 11-13-2005, 04:25 PM
ta_silver_bullet's Avatar
Default ? 124k miles on stock rockers and lifters should they be replaced?
as it says i have 124,000 miles on my stock lifters and rockers. right now my set-up is dont laugh 383 with 224/224 .581/.581 lsa 114 cam stock heads mac mids true duals and bolt-ons.
i will be switching out cam to 232/236 .57x/.58x lsa 114 ( dont remebr exact lift right now) and a set of heads they will be aftermarket just not relaesing what im getting yet and i will be going with a set of long tubes also.
i want to know what yall recomend as far as lifter and rocker replacement if yall think it needs to be done. i asume the lifters should have allreday been done but teh rockers are my main concern right now i have heard soem storie about stock rockers going out with teyh bearings it has in them.
leave feedback on what you think
Old 11-13-2005, 08:17 PM
TTT need advice
Old 11-13-2005, 08:21 PM
Ryan02SS's Avatar
With that mileage I would for sure replace the lifters and you might as well do the rockers at the same time. I kept my stock lifters when I swapped cams but they only had 16K on them. The Comp replacements seem to be a quality product, stay away from the Comp R's though as they need an adjustable valvetrain setup to work correctly it seems. To keep the cost down buy a set of relatively new stock rockers off the for sale forum or go with the rebuilt Harlands. HTH
With 124K it's simply safe insurance.
Old 11-13-2005, 08:30 PM
yeah i was asuming so i just dont want anything to happen.
how much do the rebuilt harlands run?
Old 11-13-2005, 08:41 PM
I8RICE's Avatar
I'd replace the lifters. I had 80,000 miles when i pulled my lifters and one of them fell apart. I used the melling replacements they were around $170 from Futral. I'm not sure about the rockers. But with 124,000 miles i think it would be wise.
Old 11-13-2005, 08:53 PM
that is about all that is left that has stock miles on it the motor has about 8k miles on it now. i wa sin a tight place when i put it in so i knew i wold be tearing it aprt anyway for a new cam and heads that i would do the rest then. thanks for the help any other coments are welcomed
Old 11-13-2005, 10:14 PM
ArcticZ28's Avatar
Def replace the lifters with Comp OEM replacements and pick up a set of new, or barely used, stock rockers from a board member. No reason to get aftermarket rockers, plenty of people running big HP with stock rockers.
Old 11-13-2005, 10:36 PM
yeah this is what i am planning on doing after i have doen a ton more reading i was just making sure i have everyting i need to get it done right
