Adjustable cam gear sprocket?
Old 11-20-2005, 06:35 PM
LS1 Tech Administrator
Patrick G's Avatar
Default Adjustable cam gear sprocket?
I'm going to adjust my cam timing soon. When we put in my cam, we were in a hurry and just installed it dot to dot. Now I want to put it in at a specific intake centerline. Currently, I'm running a Katech Chain on a stock cam gear set. Who makes an adjustable cam gear sprocket that will work with the stock/Katech chain? Obviously, I'd like to avoid replacing the bottom gear.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2018 Cadillac Escalade 6.2L A10 Pat G tuned.
LS1,LS2,LS3,LS7,LT1 Custom Camshaft Specialist For custom camshaft help press here.
Custom LSX tuning in person or via email press here.
Old 11-20-2005, 08:19 PM
mrr23's Avatar
someone just recently posted about a single row adjustable timing chain set. other than that, the crane double row adjustable timing set is what i use.
Old 11-20-2005, 08:24 PM
SlickVert's Avatar
Crane double adjustable here, haven’t heard of a single adjustable.
Old 11-20-2005, 09:39 PM
Bink's Avatar
Cloyes Hex adjust.
Pricey, but sturdy.
SDPC has them ->http://www.sdpc2000.com/catalog/1840...Timing-Set.htm
Old 11-20-2005, 10:15 PM
Patrick G's Avatar
If no one makes one, I can always do what we did in the old days and use an offset bushing kit. Yes, I know, it's old school, but it's worked for years.
Old 11-20-2005, 10:16 PM
Rick@Synergy's Avatar
I just make my own. Its easy to do with your current chain.
Rick
Old 12-26-2006, 05:32 PM
Restricted User
98Z28CobraKiller's Avatar
I need one also. Could you share what needs to be done?
Old 12-26-2006, 05:49 PM
pdd
pdd's Avatar
Rick
ANY PICS??
Old 12-26-2006, 05:54 PM
bigdsz's Avatar
Comp makes an infinitely adjustable sprocket, much better than the normal 2,4,6* etc. I've been using one for about 3 years. It uses the single link stock type chain.
Old 12-26-2006, 06:36 PM
hotrodrx7's Avatar
Do you know the part number?
Old 12-26-2006, 06:54 PM
Restricted User
You need the dial wheel thing for that though don't you? I want one that I can just bolt in the 4* advance position and go.
Old 12-26-2006, 07:06 PM
Ragtop 99's Avatar
WTF, you have top grade stuff throughout that motor. Spring for the Cloyes and avoid the ghetto mods.
Infinitely adjustable Comp Chain:
PART #3153KT
Old 12-26-2006, 08:06 PM
Patrick G's Avatar
PART #3153KT
I got the Cloyes Joel. Look at the date of the thread. November of 2005.
__________________
Old 12-26-2006, 10:14 PM
LS1Formulation's Avatar
lol, that's hilarious.
Old 12-27-2006, 10:40 AM
Restricted User
Is the Cloyes a single or a double roller cam sprocket? I haven't seen a single roller adjustable. Can I use a double roller and just put the chain on the front or the back sprockets?
Old 12-27-2006, 11:30 AM
Vcious04's Avatar
Originally Posted by Bink
Cloyes Hex adjust.
Pricey, but sturdy.
+1 Only good things from Cloyes
Old 12-27-2006, 12:14 PM
vettenuts's Avatar
Do you have to buy the set, or can you get the cam sprocket only? I have the Katech as well and wouldn't want to give it up.
Old 12-27-2006, 04:04 PM
Patrick G's Avatar
I used the Cloyed single row Hex-a-just on my Katach chain. Works great, but pricey yes!
__________________
Old 12-27-2006, 05:08 PM
Ragtop 99's Avatar
me--> <--- Patrick
I hate when someone uses search and brings a thread back from the dead.
The cloyes is single row and fits like a charm
Old 12-30-2006, 09:01 PM
Restricted User
Well I called Cloyes as no one was able to find me a single row LS2 adjustable cam sprocket. I guess that the LS2 cam sprocket needs to have a hump on it that the cam sensor can detect as it comes around. The guy gave me the part# as it is brand new. He told me that I needed to use the crank sprocket as well or I would throw off the chain geometry???? I'm gonna check it a micrometer to see if there is really any difference. I hope that I dont have to really change the bottom sprocket. I got the whole kit though. It was only 149.00.
Quick Reply: Adjustable cam gear sprocket?
