Which dual springs?
Old 03-08-2006, 10:41 AM
TOTM: January 2007
Last Call's Avatar
Default Which dual springs?
I currently have ls6 springs for my Lingenfelter 207/220 .573/.578 118.5 lsa cam. I thought dual springs would be my best bet because I would have some insurance. I heard that the 918's have to be changed after 25k miles and are prone to breaking.
What dual valve springs would you reccomend?
Old 03-08-2006, 11:12 AM
black_z's Avatar
I would recommend 918's. Duals are unnecessary and add a lot of valvetrain mass. Im going to run a much bigger cam than you, and I will be running 918's.
Old 03-08-2006, 11:19 AM
slowassta's Avatar
PRC golds, i would not take a chance on breaking a spring
Old 03-08-2006, 12:55 PM
black_z's Avatar
They wont break if your valvetrain is setup correctly.
Old 03-08-2006, 12:59 PM
luv2spd's Avatar
With your sized cam I would prob. just run the 918s. I'd also recommend the titanium retainers as a light valvetrain is definately a good thing.
Old 03-08-2006, 01:26 PM
black_z's Avatar
The 918's with steel retainers are MUCH lighter than duals with titanium retainers.
Old 03-08-2006, 01:54 PM
TOTM: January 2007
Last Call's Avatar
I was looking at the PRC gold dual valve springs, w/ titanium retainers, new seals, guides, and cromoly pushrods for 356.00. Seems cheaper than the 918's to me.
The 918's are $170.00 and 260.00 for the titanium retainers. More money than the combo above unless i am not reading something right.
Lingenfelter suggest the ls6 springs and said they are good to.600 lift. Kind of suprising to me.
Old 03-08-2006, 02:21 PM
freakynipples69's Avatar
For that size cam, go with the 918's, unless you think you'll be going bigger in the near future.
Hey there is such a thing as TOO MUCH valve spring. Dual valve springs on a cam that small is just not needed. With 918's setup correctly, you won't have a problem at all.
